Question about Coleman 1850 Watts Generator Each PM0401857
My coleman powermate pulse 1850 only runs on choke
Revs up and down while it is running as soon as you take it of choke it turns off
  • 13 Answers
SOURCE: no power out put
this may sound silly, but check the reset breaker buttons
Posted on Sep 20, 2008
  • 4 Answers
SOURCE: Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Posted on Jan 02, 2009
  • 14 Answers
SOURCE: Generator only runs in choke position
leak at carburator gasket
Posted on Jan 03, 2009
SOURCE: I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Posted on Apr 04, 2009
protek480
  • 1723 Answers
SOURCE: I have a Coleman Powermate Pulse 1750 generator.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Posted on Jun 26, 2009
My older Coleman Powermate Pulse 1850 is leaking gas from the grommet that connects the hose to the tank. I cannot get needle nose plyers inside the tank to tighten the nut (if there even IS a threaded nut...
I don't think there is any way to tighten or repair leak other then by replacing grommet. sorry I'm not much help but coleman powermate is no longer in business and I have had no sucess in finding a source for parts for you.Thank you and good luck.
Feb 24, 2011 | Coleman 1850 Watts Generator Each...
I have a coleman powermate pulse 1800ex generator. It stutters when put in the run position. when in the choke position it doesnt stutter.
your main jet is plugged shut off fuel, remove bowl from carb(bottom of bowl) clean out small holes on screw with stranded wire .2 holes on side on in middle. be sure to put fiber washer back between main jet and bowl and use fresh gas jor
Jan 11, 2011 | Coleman 1850 Watts Generator Each...
Coleman 1850sport plus when running pulses up and down it will only run properly with the choke half on and when shut off gas drains from carb, have cleaned carb three times no success help
double check the float ajustment and replace the needle valve for the float carb should be rebuilt kist run around $20.00 and the float about $6.00+ ajust the carb.
hope this helps
Sep 01, 2010 | Coleman Sport 1850 Generator
Can't start my coleman 1850 generator
Need more info,
Does it turn over??
Does it have spark??
Does it have fresh petrol??
Feb 25, 2010 | Coleman Sport 1850 Generator
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Erick
Mar 23, 2009 | Coleman Electrical Supplies
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Coleman 1850 Watts Generator Each PM0401857 Logo
174 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
