Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Lost power supply in moving. What is the voltage requirement
I need to seek out an alternate power supply but I do not have the old one and do not have any of the original paper work. Can someone look on their power supply and tell me any specs that show up on the power supply adapter. Might be able to find a replacement at Radio Shack.
It's 12-volt 4-amp. I don't think Radio Shack carries anything with that heavy an amperage rating, and going lower on the amperage is a fire hazard. Also, it's positive-tip polarity, although I can't tell the tip size just by looking at it. You'll need a universal with some adapters. Again, I think their adapters cap out at 1200mA (1.2 amps) and won't be enough.
I only know this because mine suddenly won't power on, so I was just looking at it. I'm really ********** because my computer's been in the shop for months, I finally get it back, and no power to the monitor.
Posted on Feb 03, 2009
    Scholar:
  • 96 Answers
I lost the Power supply for a Bell Vista 200
If you have several other Vista 200s (like in an office) you may get the specific voltage\amperage\and connector design from another power adapter. If you have that info there are many retail electronic stores that sell universal power adapters that may fit your needs. The owners manual may also designate the required voltage\current.
Aug 26, 2016 | Power Computers & Internet
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
The power supplies / ac adapters for my AW-871 speakers were both lost in a recent move. The speakers show input of 15v center + but no power spec. Do you have a suggestion for replacements? Thanks for...
Higher voltage then required is not so recommended, internal circuit may over voltage driven. some power amp max limit may fall within 18V only. See this link If your speaker power less then 30w you can choose 15V 2A will do or else select higher spec.
Jul 23, 2011 | Acoustic Research 900MHz Wireless Stereo...
Hello. I have dishhwasher model heds 968 and I am requiring information about Power supply ' Amperios for a breaker, could you send complete information Voltage 220 Volt A.C Amper :_______ A
The solution to your problem is the machine voltage must match to supply voltage, if it does not then you will require a suitably rated transformer to correct this, Note a heavy duty transformer to operate this machine may be expensive the alternative may be to purchase a machine that will operate on the supply voltage provided by your supplier. Hope this is usfull Regards Mike
Jul 08, 2011 | Dishwashers
I lost the power supply and would like to know what voltage and amps in need in a power supply to operate the maxtor
Power Requirements
AC Input Voltage: 100–240 VAC
Input Frequency: 47–63 Hz AC
here is a link to the manual : http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
Oct 30, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
I lost the power supply to my EZ1600-S while moving house. I need to know the output voltage of the external power supply so that I can replace it
There should be some hint of power output on the transformer or power requirement on the device. Please give a look on the device. I understand you cannot look at the transformer, it is lost.
http://www.gigafast.com/products/product_pdf/EZ1600-S.pdf
It appears the company that manufactured your device is out of business. If you cant find the power requirement, its time to replace your device.
Linksys makes a nice 16 port switch for under $100.00
Oct 20, 2009 | GigaFast Ethernet EZ1600 (ez1600-s)...
Adapter/power supply cord to hp speakers
Should be a marking on the speakers for polarity and voltage. Can get a 120VAC to DC adapter at radio shake.
Aug 02, 2008 | Computers & Internet
Power supply
you may try to use a universal power supply adapter by APC! check with ACER web page for the your acer monitor voltage and amperes!
May 31, 2008 | Acer Computers & Internet
Voltage
iv got same wheel and it is 24v
Mar 12, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Visioneer 5800 power supply
My power supply for my Visoneer 5800 appears to just have kicked the bucket... And, I stumbled across your post in a search for a replacement.
Anyhow, here are the specs off mine:
YHI Power Adaptor
Model: YS-1015-U12
Input: 100-120V 60HZ, 0.45A
Output: +12VDC/1.25A
Dec 16, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
244 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
