Question about Hitachi 36UDX10S 36" TV
Cable adaptor stripped
I have a Hitachi TV Model 36UDX10SA and I need the adaptor that goes from the tuner to the where you connect the coax cable. Mine is stripped and I can no longer connect the cable. Its one piece and slides into the tuner on one end and the other sticks out from the back of the cabinet. Where can I find this adaptor?
F/U guys... You advertise free solutions and then try and hose me on "premium Service" I'll find the adaptor on my own and would never consider sharing it with you you lazy bastards
Posted on Jan 04, 2009
Do they make a adaptor that goes from coax to hdmi or video plugs
No - co-ax is used to carry a signal at RF level while HDMI is audio/video.
A co-ax socket can be replaced by any qualified technician
May 04, 2015 | Televison & Video
Hitachi 35CX30B 35" TV cable connection problem.
Check the cable connector, poor signal cause the blue screen
Or check the tuner if lose solder
Jan 09, 2014 | Hitachi 35CX30B 35" TV
How to set up vhs taping
Most VCRs need to be connected in a daisy chain or a splitter from your input source. (You may need a tuner with some VCRs these days; either a digital to analog converter for a VCR with an NTSC tuner or a different tuner source.)
If you have analog cable or a cable box with coax out and a VCR with an NTSC tuner, use the daisy chain method. Connect the incoming cable or the coax out from the cable box to the VCR's coax input. Then connect the VCR coax out to the TVs coax input.
For a VCR without a tuner, you'll probably find a RCA composite video line in option on the VCR. Connect your cable box or converter box composite output to the VCR composite in. For an OTA source, you'll need a splitter to send the signal to both the TV and the converter box.
Most TVs do not have a video output option.
I hope this helps.
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I dont see a coaxial to plug in cable
This "TV" is actually a monitor. It has no tuner and thus no coax connection. You have composite, S-video and component video inputs. You will need a set-top box. If you have cable, get one that is compatible with the type of cable you are receiving (CATV (analog) or QAM (digital).) If you are getting over the air signals, the basic digital to analog tuners will work but only provide SD out. There are some HD tuner options available.
I'm assuming you have a unit with the video input board installed. (Otherwise, it would only have VGA ports.)
The manual is available here: http://www.hitachiserviceusa.com:8080/CMP4201.pdf . If the direct link doesn't work, see the Hitachi support site at http://www.hitachiserviceusa.com:8080/Index.aspx . Use the drop down menus to choose your monitor (plasma monitor then model number).
I hope this helps and wish that I had better news for you.
Feb 26, 2011 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
It doesn't have a coax connection, what type do I need ?
I had same issue. You need a converter between the cable and the tv. I found one for less than $3.
Dec 17, 2008 | Hitachi C29-F100 29" TV
Not a good signal
You may have a connection problem, particularly check the cable which goes from VCR output to TV input. The RF signal is carried on the center conductor of the coax cable. If you look at the end of the coax, you will see this center wire. If this wire is substantially recessed (too short) or bent over, then it might not make contact with the connection of the VCR tuner out or TV in. Try a different interconnection cable. If problems still remain with this substitute cable, when you have things all hooked up, try moving the cabling from side to side, and see if the picture quality changes substantially. Another possibility is the tuner in the VCR is defective. If so, repair is not economical- replace the VCR.
Aug 29, 2007 | GE VG2050 VHS VCR
Hitachi 36UDX10S 36" TV Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
