Question about Canon PIXMA iP1800 InkJet Printer
Canon mg3120 refilling ink
Resetting printer
SOURCE: reset Ink levels for canon mx310
You could just turn the ink refill monitor off.
Open the Windows Start menu, open the "Canon Utilities" folder, open the "My Printer" folder, open "My Printer", click on "Printer Status", go to the "Options" menu, unselect "Enable Status Monitor".
You should be able to tell when your ink is low, because the color will fade.
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
SOURCE: we had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Posted on Mar 13, 2009
57 varieties
  • 1653 Answers
SOURCE: resetting canon IP4600 printer after refilling ink tanks
Many ink suppliers can supply you with replacememnt chips or a reset tool. You may need to call a few before one will be willing to sell these to you but yiu will find them eventually.
Posted on Sep 21, 2009
Testimonial: "a good starting point. Thanks 57"
SOURCE: Canon PIXMA MP190 reset ink?????
I have a canon printer MP190. How do I do the reset after completing my ink cartridge to the syringe?
Posted on Mar 02, 2010
Reset ink canon ip4870
Did you replace the cartridge with genuine Canon inks, are you using non canon. or refillables? if you are using non Canon inks, they must be compatible with the printer. If you are using refillable, the microchip should be an 'auto set' one to fool the printer into thinking it is a new cartridge.
Sep 06, 2014 | Office Equipment & Supplies
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Reset canon MG3120 ink cartridges: CL 240 CL 241
you can take the cartridges out and clean the nozzles. and be careful of filling the cartridges up, you have to fill 3 cc up into each one noe more. hope it helps.
Apr 19, 2013 | Canon PIXMA MG3120 - Multifunction ...
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
I have a Canon PIXMA iP100 printer. I refilled my Canon PGI 35 ink tank and the sensor did not reset so it still says that it has no ink. Is there a way to reset the sensor so the cartridge will work?
Nope. The ink levels cannot be reset on refills for this type of cartridge. As long as your printer still prints you should be good. If it doesn't print you either need to go get another refill or a Canon brand cartridge.
Dec 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Pixima i4500 not able to use refilled inks
You can't reset the machine but the place where you buy ink should have the reset chips, or a chip resetter device that will reset the ink carts so you can refill them and use them in your printer.
Jun 30, 2009 | Canon Pixma iP4500 InkJet Printer
Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Jun 18, 2009 | Canon MP610 Photo All-In-One Printer
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA iP1800 InkJet Printer Logo
798 people viewed this question
old marine
old marine
