Question about Toshiba 50H82 50" Rear Projection Television
Toshiba mod# 50h82
The problem is when tv is turned on picture is jumpy and blurry.At first it was the vcr,and dvd inputs, Now it is all inputs and is getting worse.It seems to take longer for the picture to settle down and the top of sceen never does clear up
  • garyc349 Jan 29, 2009
    I took my tv to get repaired the tech. said it was the hyperboard,but there are no parts available.Can anyone tell me what to do.
    Genius:
  • 2,920 Answers
You have some bad ICs call a repairman before you lose the pic completely
Posted on Jan 29, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A known common problem on this models (Chassis TAC0263). A couple of ideas you may want to consider:
  • DIY (do-it-yourself) repair, perform board replacement as mentioned by welcomejee, HYPER Board, Part Number PD0264A;
  • perform component level repair. Most common faults are 10uF 16V capacitors, a good number of them. leaky, dried or blistered. Should you opt for this, it would be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings;
  • this of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required;
  • should you be uncomfortable performing a DIY, perhaps your best bet would then be to seek the services of a qualified professional;
  • if the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options and consider a replacement.
The page and here may offer additional insight as well as a pictorial illustration on performing a DIY.
Good luck and Thank you for using FixYa.
Posted on Jan 03, 2009
    President:
  • 1,952 Answers
This could be a component failure or even just a bad connection. Given that this occurred in the past and corrected itself, it suggests that the problem may be connection related. If you can solder, look on the boards for any solder connections that appear to be grainy or have rings and resolder them. If that fails, update this and we'll start looking for component failures
  • mohammed marika thambi
    mohammed marika thambi Jan 03, 2009
    There is a problem with the convergence ICs. Either there are bad
    connections (resolder the pins) or the ICs themselves are defective.
    Replace them if resoldering does not correct the problem. These ICs
    are large black ICs with about 15 pins attached to a heatsink. THey
    will be marked STKxxx
    mohammed marika thambi Jan 29, 2009
    contact tv service center tech try to repair hyperboard they available another old tv they get it ur tv
  • 470 Answers
Is the TV sited by a speaker or other magnetic device. Magnets cause this sort of problem. Can easily be shown by putting a magnetised screwdriver close to the front of the screen.
Is this an old tv? When I worked in the trade I used to regularly gave to take a degaussing machine out to the home and run this over the set.
Failing that maybe the set is just shot!
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 03, 2009
    NO IT IS NOT THE COMPONENT, but the television needs de-gaussing. This is a device that produces a high powered magnetic field to clear this sort of problem. Generally your local tv repair man should be able to sort it, but it does involve a call-out charge.
    Has the tv been dropped or hit hard? If so the tube may be damaged beyond repair.
    This can be repaired by rubbing large magnets across the screen.
    Scholar:
  • 96 Answers
Seems like a board gone down ... or going to fail ...
Not really a lot you can do, except weigh up whether it's worth getting a shop to fix it or just buy a new TV in the January sales.
  • 15,935 Answers
1Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section. Step2Enter the menu on your TV. Use the remote control and bring up the menu. Step3Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options." Step4Select a color. You will have red, green and blue to choose from. Do each one, starting with red. Step5Press "Enter." A crosshair pattern will appear on your screen. Step6Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair. Step7Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair. Step8Save settings. It is important to save your settings when you are done, instead of simply exiting the menu. Step9Repeat these steps for all colors.
  • blueextc3221
    blueextc3221 Jan 03, 2009
  • blueextc3221
    Sorry about the dual post.
    If you go to the following link and register for free....
    the owners manual will be available tou you.
    Setting the convergence manually will be on page 25.
    http://www.retrevo.com/support/Toshiba-5...
    Genius:
  • 1,036 Answers
Try just plugging one input in and try that. Sometimes it's an interference conflict between inputs.
It could also be a faulty connector.
  • 10,594 Answers
Hyper board in Toshiba TV needs to be replaced and qualified TV Tech will do this job.
  • Shahid Electronics
    Shahid Electronics Jan 29, 2009
    Please ask TV tech try to repair Hyperboard on component level if board is not available.
Have a perfect picture but no sound. What can be the problem?
Toshiba says:
toshiba_icon_white.pngIf there is no sound from the TV try the following:
  • Ensure the TV isn't muted.
  • Check that the TV speakers have not been manually turned off in the menu settings. Refer to the User's Guide for your specific model TV.
  • Ensure the input for the connected device (DVD / Blu-ray / Cable / Satellite / Game Console) is set properly on the TV. Click here for help with TV inputs.
  • Check that the connected device audio settings are configured send sound through the audio input connected to on the TV. Refer to your device manufacturers instructions.
  • Make sure the connected device does not require a separate audio connection to the TV
Jan 28, 2015 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
Mar 27, 2012 | Toshiba 50H81 50" Rear Projection...
I have a toshiba 52 in projection tv Model number 50H82 and the picture is really blurry with lots of vertical lines
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Toshiba 50H82 50" Rear Projection...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Issue with our Toshiba 50H82 - overnight it has stopped playing DVD's properly - a solid black rectangle obliterates 75% of the screen. Any idea?
Do you see same solid black box in all inputs or just in dvd picture?
If solid box appears only with dvd picture then its generated by dvd player, check dvd player Menu and turn off any subtitle settings.
And if solid black rectangular appears in all inputs of TV like cable etc then check Close Caption feature in TV and turn off CC function.
Hope this will solve your TV problem.
Thanks.
Nov 29, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 65HDx82 video problems
I had a similar problem with a similar model by Panasonic. Unfortunately you will need a certified tech. to pick it up and repair it at there shop. It cost me around $400 bucks and when I received the TV back the remote no longer worked and the repair shop did not man up to the fact that they where liable. They just said they would order another signal reciever for the TV and never did. So, good luck. It is reparable just be careful who you deal with.
Oct 04, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
Toshiba 50H82 50" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
