Question about Gateway GT5220 PC Desktop
Want power up
When i hit power button fan , cdrom run but system want bootup, keep hitting power button and finally system boots
  • Anonymous Jan 06, 2009
    i have a gateway and i cant get it to power up at all it goes to a we appolagize there is a systems error i have tryed every solution they give and none will work can u help
  • Anonymous Jan 09, 2009
    power and fans run but no video, no sound from bios, I guess is the motherboard
  • 61 Answers
Clean your ram and re try
Posted on Jan 05, 2009
R15d notebook screen black, fans running
either your backlight has failed or you have hit one of the function keys which selects external monitor- can you connect it to an external monitor to see what happens?
May 21, 2014 | Microsoft Computers & Internet
Acer aspire x3812 power button
Check your hard drive, run a diagnostic. You may be able to boot into safe mode. Turn on the system and keep hitting the F8 key immediately. If that doesn't do it then try to reinstall the operating system. You may have a currupted Boot.ini or load manager. Lastly if you recently installed any device or program uninstall it. Good Luck
Apr 22, 2014 | Computers & Internet
Shuts down on boot up
hi sir,
Does it just shuts down or it reboots?
If it shuts down this type of problems can be resolved by scanning the computer for a virus or
using the Windows Repair Disks. During boot if you can hit F8 and use safemode with command and prompt.
1 Type CHKDSK/F then hit enter
2 Press Y then hit Enter then reboot to see if this works.
If it reboots while booting up then.
Other things that might be preventing the computer to boot up most likely is the memory.
Take out the memory put it on a different slot or try a new memory.
Also make sure that the power supply fans are not dirty this prevents the computer to bootup.
Jan 24, 2011 | E-Machines T5212 PC Desktop
Hi... I have a problem during installing Windows Xp in my laptop, im getting an error message like 'setup did not find any hard disk drives installed in your computer.... plz.. help me out...
reboot your computer and hit f2 when you first see the logo popup, this will take you into the setup. Arrow over to boot at the top of the screen.hit f5/f6 until your cdrom drive is first on the list. Arrow over to exit and save changes and exit. Before you hit enter, put your XP cd in the cdrom so it will boot to cd when you restart. You should be able to reinstall windows doing this. When you are done, to reverse the process and return your bootup to normal default, hit f2 at the logo, when you are in the setup utility hit f10 to load setup defaults and exit, your computer will reboot and you should be good to go!
Oct 11, 2010 | Computers & Internet
How to install windows xp in lenovo G460
if you have the windows XP disc. put it inside the cdrom drive then restart the computer. keep on tapping the F12 key once the computer is restarting. you will be rprompted with boot options. select your CDrom drive as boot device then hit enter. your computer should boot now using the cdrom. XP installation should be running now.
May 07, 2010 | Computers & Internet
HOW TO ENTER CMOS SETUP OR BIOS SETUP OF SONY VGN-FW290E OR HOW TO INSTALL WIN XP IN THIS NOTEBOOK
To enter the CMOS setup BIOS you hit f2 during the power on. After you enter the bios to the boot up screen and select first boot up = CD ROM. Save the configuration and reboot. Now pop in your windows XP cd into the CDROM, your computer will bootup from the CDROM. You can now reinstall windows.
Dec 11, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
I have to hit the f1 key to continue the bootup process. Then I get a defective fan error message, but the fan is running, becasue I can hear it.
there may be more than one fan-- there also is a setting in the BIOS to disable the fan warning if you are SURE that the fan it is monitoring is working correctly.
Jun 24, 2009 | Gateway M350 Notebook
Loading errors, after reinstalled recovery disk
BEST SOLUTION:
it might have corrupted the NTLDR thats the windows loading file system...
plz...do the following :
>>put the windows XP disk..
>>restart the system>>hit F2 or DEL as soon as system starts..
>>change the 1st boot device menu to CDROM...
>>then restart the system and hit any button as soon as it says "click any button to boot from CD"
>>system will boot from CD and windows setup will come up....
(CHECK THE LINK www.windowsreinstall.com)
>>hit R for recovery console to load....
>>then hit number 1>>
then it will show as C:>
>>type bootcfg /rebuild
>> follow the steps and then after it has been completed >> type exit
>>restart the system normally
May 11, 2009 | Computers & Internet
Computer won't boot
turn off the system remove all the cables from the back of the computer press and hold down the power button for 10 seconds now connect just the poer cable and try to tun on the system and as soon as it turns on tab the F8 key on the keyboard and then boot into last known good configuration
May 28, 2008 | Computers & Internet
Boot up problem
plz check the first boot device is hard disk in your bios setup if it is not then make it, then put your findings here
May 27, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Gateway GT5220 PC Desktop Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
