Question about JVC AV-32230 32" TV
Tv remote has range of only two inches
TV is JVC AV 32230, I bought new remote but again only the two inch range, the range is normal for VCR and DVD
  • JVC Master
  • 5,568 Answers
It's pretty clear that the problem is being caused by the TV's receiver, not the remote. In some sets, the receiver is on a separate small board with the IR detector and its immediate circuitry. If you can access that board (after leaving the set unplugged for at least a couple of hours), it will have an assembly part number and you might try ordering that from JVC although support for CRT sets is on the decline. Removing the rear housing isn't tough; there are perhaps a half-dozen (Phillips) screws to remove around the edge and possibly another one or two toward the center of the input panel.
Posted on Jan 03, 2009
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
The TV shuts off automatically and the Timer On button on the front of the TV flashes. The TV will not start again, either manually on the TV or with the remote. If we unplug the TV, leave it off for a few...
sound like timer setting on . you need to go to setup menu the timer set it off, if not , you need to check power supply unit, high value capacitor if under reading replace it. good luck!
Jan 27, 2010 | JVC AV-32230 32" TV
JVC AV-32230 TV
Although I've had some success soldering a few of those lugs back into place, it will be more dependable to replace it with a new part. The TV says, "no user serviceable parts inside". A technician would be your best bet. He should give you an estimate in advance.
Jul 09, 2009 | JVC AV-27530 27" TV
Can not turn on tv.
Just press the buttons on the TV randomly, sometimes this combination works in starting the TV w/o a remote. After that use the remote for the dish to flip channels, but you will have to set the sound manually from time to time.......sodeep
Jun 13, 2009 | JVC AV-32120 32" TV
My jvc av 32230 has no chanells only blue screen
what you need to do is go into the menu and select the channel program, so the tv will find any channels that are coming through the cable line. so make sure the input is set to cable and tv.
Dec 16, 2008 | JVC AV-32230 32" TV
Lost tv code
Here are some of the codes2.gif still looking for manual
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Mitsubishi TV4.gif 0093, 0150, 0178, 0019
JVC2.gif VCR 0067, 0041, 0008
JVC DVD1.gif 0558, 0623
samsung1.gif codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola2.gif Cable2.gif Box: 5000, 5003, 5046, 5047, 5052
Comment by Gigatech, posted on Dec 10, 2007 Here is some helpful information4.gif I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device4.gif button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Jan 03, 2007 | Jensen 143307 Remote Control
JVC AV-32230 32" TV Logo
81 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
