Question about Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Can I upgrade from Hayward 2hp ao smith pool pump to 2.5hp
    Scholar:
  • 111 Answers
Yes you could upgrade the motor from a 2.0 to a 2.5 but this will not result in an increase of your water/pressure flow?
This would slightly reduce the load on the motor as the impeller inside the pump is specifically matched to the your motors amperage.
Posted on Oct 30, 2012
  • 59 Answers
SOURCE: how do i tear down impellar housing on ao smith
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
Posted on May 25, 2009
  • 396 Answers
SOURCE: We have a Hayward Motor A.O Smith Model C48J2N131
you need to lube the motors shaft with electric motor oil they sell it in any hoby shop
Posted on Oct 29, 2009
  • 100 Answers
SOURCE: Is it possible to replace the bearings on a AO
any good electric motor shop should be able to
Posted on Feb 14, 2010
  • 366 Answers
SOURCE: 1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Posted on Feb 22, 2010
Testimonial: "Great. Thanks for the quick feedback. I look forward to saving a few $'s this year operating my pool. Cheers!"
  • 8404 Answers
SOURCE: my hayward 2hp ao smith turns on then kicks gfi
I think you have a failed start capacitor. Have your motor looked at by your professional pool supply.
Posted on Jul 24, 2010
Rcvd new pentair 1 hp pool pump replumbed and did the electrical connection. motor get real hot and shut off. i used the correct 12 ga wires and wire it for 115v. do you think i got a bad pump. it did...
Assuming everything is electrically correct, the motor probably has a short in the winding somewhere. The motor should have a one year warrantee on it. Any pool store ought to be able to trade it out for you.
Sep 14, 2013 | AO Smith 2hp Pool Pump Motor Ao Smith...
I am looking for a parts diagram for an A.O. Smith pool pump motor SP3220Z1BE.
The motor is made by A.O. Smith in Tippton, OH. You can try calling them, and with any luck you may get a kind soul that can get you a splsh sheild. It is probably not a part you can purchase from a distributor, but that is an option you can also pursue. Good luck.
Mar 05, 2013 | Hayward 2HP Pool Pump Motor A O Smith...
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
My hayward 2hp ao smith turns on then kicks gfi breaker after a couple seconds. after several tries it works ok.
Jul 18, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP Logo
56 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
