Question about Coleman Powermate Powermate 5000W Generator
What weight oil for the Colemen Powermate 5000
  • 59 Answers
SOURCE: Oil
Coleman 018-0060ct air compressor oil or equal
most hardware stores will stock it.
Posted on Aug 31, 2008
FRANKSFIXIT
  • 72 Answers
SOURCE: Oil for Coleman Powermate 5000 PM0545305.03
My answer:
First of all - Almost every 4-stroke Genset engine out there should use a minimum 10-30 or else a 10-40 oil blend tops. Best NEVER to use just a straight weight, as in a 30 or 40 weight, as that would be way too "high viscous" at colder temps and could destroy the engine due to overheating at MAX Genset LOADS!
Next - If the Genset is indeed brand new then you need to use the proper fuel in it, as certain mfr's require different fuel blends (such as with certain B&S - Briggs & Stratton - engines), and those engines are set up that way to run on that blend alone. Using the wrong gas blend could damage the engine.
You really need to get a factory Users Manual for your Genset there and read it through thoroughly!
If it has gas in it now (and hasn't run in 3 years?) chances are the whole gas tank, and fuel lines, and Carb as well will need to be cleaned out from contaminated fuel - as there definitely is gum and varnish built up everywhere in those fuel delivery areas esp the most important component - the Carb! Been there - seen that - cleaned that! So I KNOW for FACT.
As for the OIL LEVEL - that is fairly simple - as all you do is unscrew (or in some cases pull out) the dipstick, and check the oil for proper level on the stick as well as cleanness (2 finger test like with car oil), and if it's even black or a silvery color then it definitely needs to be changed out NOW! Refill with fresh oil and your done there.
Check the Air Cleaner for cleanness as well, and service the filter if a foam element, or replace it if a paper element.
If the fuel tank has an in-line fuel line filter and it looks dirty change it out as well. Esp if the gas tank is made out of metal.
Check the spark plug for proper gap, and heat range, and burn color if the Genset has been run already. Should be a nice "light tan" color. If dark and wet - then you have Carb flooding problems.
That about covers it...
Anything else problem wise feel free to ask me here in post follow-up and I'll be glad to answer it for you.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 04, 2008
CarlGehrke
  • 169 Answers
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Posted on Dec 14, 2008
  • 149 Answers
SOURCE: Oil requirements for Powermate 5000
10-30W or a SAE30. usualy 600mls 0r 1200mls
Posted on Jan 30, 2009
  • 120 Answers
SOURCE: WHERE CAN I GET A NEW CARBURETOR FOR COLEMEN
If you have a local small engine shop. They can help. If not, try ebay.
Posted on Jun 03, 2009
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
What oil wieght oil does the powermate 5000 use
a 10-30 multi weight oil should work fine, in the winter, if it gets cold there, a 5-30, if it gets super hot in summer, a 10-40
Mar 10, 2013 | Coleman Powermate Portable Generator...
I have a Coleman Powermate 5000 Model number PC54-5000 serial # 56980042 attached to a Briggs and Stratton 11 HP motor. It came to a grinding halt the other day and oil came seeping out between the motor...
A lot of these have a Woodruff key and are on a taper.
Some have success in seperating by putting a bolt in the end of the rotor shaft and pulling with a slide hammer to seperate. Make sure bolt has MANY threads engaged. Slide hammers are an autobody tool with a weighted handle that slides on a rod until it hit the end stop giving a sharp pulling force. Some have tried to fake this using a chain and a weight to give a yank on the bolt.
I can't be sure about yours however.
Apr 06, 2010 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
WHERE CAN I GET A NEW CARBURETOR FOR COLEMEN POWERMATE 5000
Mar 05, 2009 | Coleman Powermate Powermate 5000W...
Jan 27, 2009 | Coleman Powermate Powermate 5000W...
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
146 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
