Question about TallyGenicom 9022 Laser Printer
Driver tally genicom 9022 - TallyGenicom 9022 Laser Printer
SOURCE: paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Posted on Jan 28, 2009
SOURCE: "check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Posted on Mar 11, 2009
  • 169 Answers
SOURCE: TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Posted on Jun 22, 2009
allanhunt
  • 135 Answers
SOURCE: DRIVER
Try this link:
http://www.liutilities.com/device-driver/tallygenicom-6306/
Posted on Mar 28, 2010
  • 114 Answers
SOURCE: t6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
Posted on Jul 18, 2010
Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Mar 21, 2012 | Office Equipment & Supplies
Need a Windows2008r2 printer driver for TI/Genicom 8920
I am afraid the TI 8920 is a rather old model of printer, with the Texas Instruments brand or printer long discontined and with the demise of Genicom there are no Windows 2008 drivers for this printer.
You may wish to use the Generic Text only printer driver inculded within the Windows Add Printers Wizard, I do not belive there is any alternative
Dec 06, 2011 | Tally Genicom/T.I. 8920 Printer
How do i find the IP of 9022 Monochrome Laser
First, are you sure you have network capability. This is an option. Since there is no control panel display on this printer, you'll have to use the configuration software provided by Tally Genicom.
Jul 20, 2011 | TallyGenicom 9022 Laser Printer
T6312
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
I have printer genicom 4440 xt and have not a driver i want a diver for this printer thank you
Just try using a generic print driver in windows. This driver will send standard ASCII code and the printr should allow you to print standard text. try it.
Apr 10, 2010 | Tally Genicom 4440 Printer
Paper won't feed
roller of paper is either worn out or the belt is missplaced try to open it and see it running feed the paper with your hands and if it works replace the rollers
Jan 20, 2010 | Canon Pixma MP500 All-In-One InkJet...
Is there a driver available to make the genicom 4840e printer work with vista?
Get the 32bit XP driver and attempt to install it using compatibility mode or you can try this 3rd party driver but no official support for Vista.
Dec 03, 2009 | Tally Genicom 4840i Printer
TallyGenicom 9022 Laser Printer Logo
79 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
