Question about Epson RX620 All-In-One InkJet Photo Printer
Epson RX420 new black ink cartridges displaying empty
I have replaced all cartridges, the 3 colours are fine, but the printer is saying the black ink is empty. Have changed it for another new epson cartridge, but same message. Any help please? Many thanks.
  • The StickMan Jan 27, 2009
    I have another cartridge doing the same thing as your Black one is doing, mine is the T 486 Light Magenta I have 6 cartridges in my printer 5 colour and 1 Black. when someone tells you what to do let me know to please thanks.
    Rgs
    The StickMan
  • jolexi Jan 30, 2009
    I took the printer to a repairer, and it turns out the cartridge I had bought on ebay was a refilled one, leaking, and the compatable one was the incorrect one. A new epson cartridge was put in, and no more problems. Thanks to everyone for their help.
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Compatible non epson ink not working
Epson has gone to great lengths to block compatible cartridges. Many of them simply dont work. Even those that do, you sometimes have to replace ALL of them. A mix of some Epson and some of another brand may give you the results you got. So you have to decide if you will continue to pay Epson's rip off prices or if you will buy a set of compatibles (which costs as much as one epson cartridge), do a one-time complete replacement, and then save money for the life of your printer.
I am using special reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink than Epson and cost me under $3. The ink is in a separate tank inside the main cartridge. When the ink is empty, I pop out the tank, pop in a new one, and the cartridge automatically resets to full. This is great because Epsons have a habit of reporting out of ink when there is still 10-15% of the ink left, so I can pop in an "empty" cartridge and still get more pages out of it. And I was able to use some of these together with some genuine Epson without problem, though the site says they can't guarantee this will work for all printers.
Jul 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I know the colours and black crtridge is not empty RX420 Epson
thats true because the capacity of ink of cardiges small refill it it will print. trust me.
Jun 04, 2009 | Epson Stylus C66 Inkjet Printer
Epson RX420 has all lights flashing + E in the display, Have just changed ink cartridge and problem occured
OPEN SSC UTILITIES,DROP DOWN CONFIG BOX,SELECT RX420 MODEL,CLOSE BOX,THEN RIGHT CLICK ON TRAY ICON AND SELECT INK FREEZER,AND RESTORE VALUES BACK, OK ON COMPLETION,THEN RESTART YOUR PRINTER AND ALL SERVICE LIGHTS SHOULD BE OFF.
IF YOU HAVE ANY FURTHER ISSUE LET ME KNOW
THANKS
KEVIN
May 05, 2009 | Epson Stylus RX425 Multifunction...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Not recognizing ink
Hi there
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Aug 23, 2008 | Epson CX7800 Stylus Color All-In-One...
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
211 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
