Question about GE Spacemaker JVM1640SJ Microwave Oven
How to test a diode
I want to see if the diode is good for my GE SPACEMAKER XL1800 is good.
  • richhall19 Jan 03, 2009
    I read on the internet that if I test continuity and get a signal changing polarity in both directions it shows the diode is shorted. If I get no signal from eather end when changing polarity it shows the diode is open. Thay then said that the dioed should be replaced. I used a continuity tester with a small 9volt battery like used in a smoke alarm. I
    Genius:
  • 1,036 Answers
To test a diode, first remove it, then use a test meter with a diode check facility. Test component first one way around, then the other. It should give a 1 in one position, and 0 in the other if all is ok.
This is the correct way to test a diode.
Posted on Jan 03, 2009
  • Richard Perkins
    Richard Perkins Jan 04, 2009
    You realise that by rating this as helpful, you're actually pulling my rating down from 88% ?
    Did I misdirect you?
    Was the information wrong in any way?
    Would you reconsider your verdict please.
    Yes you can use a higher voltage, and check diodes in this way, but you can also blow them up in the process - giving a voltage in both directions. Using a very low voltage logic device - there is no risk of this.
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
GE Profile Spacemaker XL1800 The microwave runs, the lights come on, timers goes, but it does not heat/cook and it makes a loud buzzing sound.What is wrong with it,and can I repair or trouble shoot it?
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 29, 2010 | GE XL1800 1100 Watts Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Disconnect the wire connection on touchpad
Do you mean the keypad strip?
Jan 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
Spacemaker XL1800 runs but doesn't heat.
I think you should check the fuse first that runs the magnatron if the fuse is good that means the magnatron is bad! but if its only the fuse then you save time and money!
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
362 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
