Question about Tomtom ONE GPS Receiver
My tomtom, one will not power up - Tomtom ONE GPS Receiver
  • camobabe26 Feb 06, 2009
    my tomtom is doing the same thing and i just bought it
    Problem Solver:
  • 7 Answers
The Tomtom buttons are actually misleading sometimes because they have to be held down for a few seconds before they turn on.
  • Make sure you are holding the button down long enough.
  • Try plugging your TomTom into your car AND usb port on your computer and turning it on. If it turns on, this may indicate a problem with the batter charging.
Posted on Feb 06, 2009
How do reset my tomtom 20
Press the power button down and hol down for approx. 20 seconds. When you hear the tomtom 'drums' let the power button go and wait about 60 seconds for a full reset and boot
Mar 12, 2013 | Tomtom One Europe v2 GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Tomtom not turning on
It sounds like the dreaded green light of death. The TomTom car chargers for this model and older had a inherit problem with sending more than the requaired amount of power to the TomTom 3rd edition and older models. When the extra power is supplied a diode in the TomTom burns out, but the green power light will come on.
Nov 29, 2009 | Tomtom ONE 3rd Edition GPS
Where is the reset button on the Tomtom xl340s
The TomTom XL 340-S uses the power button as a reset. With the unit turned off, hold down the power button for approximately 15 seconds, until the TomTom turns on. As soon as the unit turns on, release the power button. The unit is now reset.
Nov 21, 2009 | Tomtom XL 340S Car GPS Receiver
I CANNOT START MY TOMTOM XL IN MY TRUCK
when i connect dc power cord connect the tomtom xl will not start
Jan 11, 2009 | Tomtom One XL GPS Receiver
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
Tomtom Go 920 failure
The power light only shows that power is getting to the TomTom. It proves nothing else and doesn't even confirm that the internal battery is charging. If you have tried a reset ( by inserting a paper clip into the reset hole at base of your TomTom and that hasn't worked then it's likely you have blown internal components . Usually caused by faulty charger. I hope the reset works ... good luck
Oct 20, 2008 | Tomtom GO 920 GPS Receiver
TOMTOM ONE
www.tomtom.com/9091
uninstall and then reinstall the app
Jul 28, 2008 | Tomtom ONE 3rd Edition GPS
TomTom will not switch on even when it is plugged into the mains power
yes just press the reset button under the tomtom you can find this next to all the pins where your tomtom dock goes in.
Dec 17, 2007 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
46 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
