Question about Brother Office Equipment & Supplies
Mfc 640 cw service manual - Brother Office Equipment & Supplies
  • 60 Answers
SOURCE: fax manual for brother mfc 490 cw
Go to http://www.brother-usa.com/Manuals/Default.aspx
Select Product and then model and download.
Posted on Aug 26, 2009
  • 31 Answers
SOURCE: Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Posted on Oct 22, 2009
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
  • 159 Answers
SOURCE: how do i errase memory from my brother fax machine
Putting the machine in Maintenance Mode will allow clearing all memory, but will also allow you to enter things which can totally mess up your machine, so be careful here...
Entering maintenance mode, method 1:
From normal ready state, enter:
Menu
* (Star on phone keypad)
6
[You MUST touch all those buttons within 2 seconds, or the machine will just leave you in the menus somewhere. If you slow down to let it finish beeping, you'll miss it. Press Stop and try it again, faster. Look for the word MAINTENANCE on the display, and/or all light flashing together.]
Some Brother models dont use method 1; they require Method 2:
Menu
Black Start
Up-arrow
Up-arrow
Up-arrow
Up-arrow
Success is indicated the same way as in Method 1. Try either method to see what works.
Once in Maintenance Mode, you have two choices. For either one, just enter the two-digit number. You don't touch Start or Enter, just the two digits.
91 Clears all memory except your phone directory and a few important things like that.
01 Clears everything, leaving your machine just like when you first unboxed it.
99 Takes the machine out of Maintenance Mode. It will take a minute to go through its entire startup routine, as if you'd just plugged it in.
Posted on Feb 15, 2010
Testimonial: "this time to fix my printer was so easy and fast I am realy happy whit the service."
Patzky
  • 240 Answers
SOURCE: My MFC 685 CW will not print.
Hello ,
First, we will have to make sure the printer is properly connected to the network
  1. Go to your printer.
  2. Press “menu” and scroll down to network, then WLAN
  3. Go to TCP/IP
  4. Go to IP address. Make sure there is an IP address here (not 000.000.000.000). Change the last 3 digits to “050”
  5. Change the boot method to “static”
If your IP address is not a valid one (all zeroes) or is an APIPA address (starting with 169.254.#.#) you will need to run the wireless setup wizard again as the machine is not properly connected wireless
If you had a valid IP address before changing anything, it means that the printer offline is caused by the computer not being able to locate the printer.
This is usually caused by the printers IP address changing.
Changing the boot method to static will make sure the IP address on the printer does not change.
Now we will have to make sure the computer knows where to find the printer.
On your computer, go to your start menuè control panelè printer
Here you should see your brother printer. Right click on the printer and select “properties” (If you are running windows Vista, make sure select “run as administrator” and then properties)
Go to the “ports” tab
Select “add Port…” and then double click on “standard tcp/ip port”.
This will bring you to the add port wizard, click next.
In the field for “Printer name or IP address” enter in the new IP address of your printer and then press next and finally “finished”.
Make sure to apply the changes.
You should now be able to print.
Thank you,
Posted on Mar 29, 2010
I misplaced the instruction manual for my Brother MFC490CW. Where can I purchase one?
Improve the FixYa.com experience for everyone by voting!
I trust that this answer and definition are responsive to your question.
The heading on your query states 'Problem with Camcorders'. My database indicates the MFC-490 CW is an all-in-one printer.
If you want a FREE user manual, click on the following link and follow the instructions: BROTHER MFC-490-CW USER MANUAL DOWNLOAD
All the best,
Ben
Jun 28, 2011 | Video Cameras
How to use brother mfc 495 cw wireless to my computer do not have manual
i am trying to install the printer software and it is saying it needs to be configured to the wireless router, HOW DO I CONFIGURE IT TO THE ROUTER? I HAVE A BROTHERS MFC495-CW WIRELESS PRINTER.
Apr 23, 2010 | Brother MFC 420CN All-In-One InkJet...
My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Mar 27, 2010 | Brother MFC 490cw Color Inkjet...
Fax manual for brother mfc 490 cw
Aug 26, 2009 | Brother MFC 490cw Color Inkjet...
Printer wont print black
did you try the 'cleaning' function yet?
Oct 28, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 640 CW
mike,
just press menu then start bk-copy then fourtimes arrow-up quite quickly one after another to get to the maintenance menu.
Mar 26, 2008 | Brother MFC-640CW All-In-One InkJet...
INSTALLATION
this is a complex machine, without its documentation it would be very hard to figure out, so the install and setup guide is available from brother, its available here
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_665CW_EN_382.PDF
and here is the units operator manual, this will take you to it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_440CN_665CW_845CW_EN_287.PDF
following the install guide is pretty straight forward and should result in a satisfactory setup.
Oct 17, 2007 | Brother MFC-5460CN All-In-One InkJet...
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
