Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
Locking mechanism on miter saw.
The hubby left the miter saw in the locked position and I need to finish a home project this weekend. He is out of town and I can't reach him. Exactly how do I unlock the head of the saw to the upright position so that I can use it. Thanks
    Problem Solver:
  • 6 Answers
Push down on the handle . Facing the saw there is a spring loaded pin on the left rear side , right at the pivot point , pull out on it and raise the handle to the up position.
Posted on Jan 03, 2009
How do i unlock dewalt dws780?
Curious if you got an answer? My Model 36-230 miter saw is locked in doen position and I can't get it unlocked and upright.
Jun 07, 2014 | Dewalt Miter Saws 12" Double Bevel...
RK7136 locked in safe position . How do I unlock
I am guessing you got an answer by now, but I saw on Amazon someone asked this recently. I remember this problem when I got mine. I assume you mean the arm that lowers and raises the saw, not the locking mechanism for the table. As you face the saw, look at the guard. There is a slightly curved arm that goes from the guard toward the back of the saw. On the piece the guard arm attaches to at the back of the saw on the left side, there is a "pin" that sticks out on the left side. It looks like a bolt that is longer than the others near it. Gently push down on the top of the front of the saw to take pressure off the arm pin, and then just pull the pin to your left, like you were trying to remove it. It doesn't come out all the way, but releases the lock. If you have kids around, best to lock it when not using it...safety first. Oh...and their manual sucks!
Dec 13, 2013 | Rockwell Rk7136 1 Shop Series Miter Saw...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
http://www.searspartsdirect.com/partsdirect/part-model/Makita-Parts/Saw-Parts/Model-LS1220/1339/0744300/P8100100/00002?blt=06&prst=&shdMod=
Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
I have a Makita LS 1013 compound miter saw. The locking knob that locks the saw from sliding back and forth no longer works. I downloaded the owners manual and parts list but I can't seem to correctly...
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
Dec 19, 2010 | Makita 10" Miter Saw LS1030N
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Sep 20, 2009 | Makita 10" Miter Saw LS1030N
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
I have a ms 150 miter saw that a relative gave me. Blade needs to be changed but the locking mechanism is stripped. How can I remove the bolt that holds the blade in place. Also the blade turns clockwise...
Jam a piece of wood between the blade and the table to stop it from turning while loosening the bolt. Circular saws never had locking mechanisms until recent years.
Mar 15, 2009 | Saws
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
1,475 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
