Question about Kenmore Elite 45986 Front Load Washer
Door will no open.
Help,
I have a washer that keeps alarming F and dL. The door will not open to take my wet clothes out. What do I do? Any solutions?
  • 640 Answers
Sorry door lock failed..is on the way out,,replace door lock...
Posted on Jan 05, 2009
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Ocassinally my washer machine won't start, it Makes a sound of an alarm showing DL and then F. I shut it down and I quick it at the entrance of water area and then she starts. What should I change?
'DL' + 'F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Please score this solution accordingly. Thanks!
Apr 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite HE4T quietpak 9 washer. It has stopped the wash load with about 11 minutes left several times. It gives and error code DL then F alternating. The door remains locked and anytime...
The error you have is due to a failure in the door latch mechanism. There is a way to manually open the door if you are a little handy I can send you some instructions, it requires pulling the lower panel off (3 screws).
Let me know if you want me to help on this.
Phil
May 20, 2010 | Kenmore Elite HE4 Electric Dryer
Wash cycle stops with 1 min left and clothes are sopping wet
dl mean door lock system fail. may be lose connection on your door lock or control board.
May 23, 2009 | Washing Machines
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
My Front Loading Washer is 14 months old. It is not working properly. The door locks & fills with water. The soap is dispensed. You can hear the motor running but the drum doen Not turn. The alarm...
it sounds like a faulty door switch,when you close the lid,it pushes a switch in letting the washer know its safe to spin,replace the door switch ,it is a common problem as the switch is being pushed constanly open and closed,usally held by 2 screws
Jul 07, 2008 | Samsung Washing Machines
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
