Landis & Gyr Central Heating programmer
I need a copy of the user manual for the RWB-XP programmer already installed in the house I have recently moved into.
  • 251 Answers
SOURCE: We need a wiring diagram for Central heating
http://www.honeywelluk.com/product.aspx?r=pp&p=2470
hope this helps
if it does please vote , if that site dosent allow you in you might have to register with them , or alternatively post your email address and i'll send you the installation guide
Posted on Nov 14, 2009
SOURCE: I need the user manual/instructions for a
I got in touch with Honeywell by email and they sent me the manual on pdf.
Posted on Jan 12, 2010
SOURCE: ideal classic boiler no heating only hot water
Hi I have some boiler problems, I`m the proud owner of an Ideal classic SE12ff. The controls are that of Sunvic select Xl.
The problem is I can only get the hot water to work when the heating is on, I neglected this over the winter but now the summer is apparently fast approaching I am desperatley trying to get this solved. A plumber has done some fault finding with no prevail, have you any suggestions?
Posted on Apr 23, 2010
  • 2523 Answers
SOURCE: I have recently been installed with new central
0 t0 5 is the range just set the to what number gives the temp you like in that room thats it
Posted on Nov 27, 2010
  • 5 Answers
SOURCE: Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
Posted on Mar 04, 2011
Landis gyr meter manual
computer software ?
PDF]User Manual - Landis+Gyrwww.landisgyr.eu/product/map/?download=78003
Apr 29, 2017 | Cars & Trucks
I have a gas meter and pay as I go card but the machine will not accept my card , what do I do "?"
Call the card companie and see if you have funds on the card. Sometimes I think I do and then I didn't realize the fees ate it up. Or they could have shut off your card.
Jan 04, 2015 | Siemens Landis & Gyr 536 765
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
How do i reset a landis prepaid meter
You do realise that the itme you are asking about is not a computer motherboard, don't you? It is a heating system controller.
Apr 21, 2013 | Siemens Landis & Gyr 536 765
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
My daughter has just moved house and inherited a Randall 702 time unit for her central heating but no manual was left. Where can she download one for free, please?
This programmer is very easy to use, I wish I could get a modern one so simple.
Use the 6 white buttons along the top to move the time setting bars to the desirded on/off times.
Then using the two rows of switches below decide if you want hot water or heating between the time bars.
Switch 1 is for operation between bars 1 & 2
Switch 2 is for operation between bars 2 & 3
etc
but Switch 6 is for operation between time 6 and time 1 the next day.
The slider switch has 3 positions
Off, Auto (ie the time settings above), and On all the time
Hope this helps but if you are scrapping the programmer please let me know
Dec 18, 2010 | Heating & Cooling
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
