Question about Dell Inspiron Mini 10 10v 1010 1011 PP19S Series Laptop Auto Car Adapter (C1930SUU3170B473B3)
Dell inspiron mini 10 model pp19s wireless driver window xp
2 Suggested Answers
  • 1027 Answers
SOURCE: how to remove bios password in laptop dell model
BIOS passwordsare used to add some extra security to computers. You can either set a passwordto prevent access to BIOS settings or to prevent PC from booting. But sometimesthis extra security might become a pain when you forget the BIOS password orsomeone changes your system BIOS password intentionally. But there is noneed to worry. There are many known ways to reset / remove / bypass thepassword: · By removing CMOS battery · By using motherboard jumper · By using MS DOS command · By using software · By using Backdoor BIOS password Now I'll try to explain each methodone by one: By Removing CMOS Battery:
Almost allmotherboards use a small coin d CMOS battery to store all BIOS settingsalong with the password. To reset the password, unplug the PC, open the cabinetand remove the CMOS battery for approx. 15-30 minutes and thenput it back. It'll reset all BIOS settings as well as the password and you'llneed to re-enter all settings. If it fails,then try to remove the battery for at least one hour. By Using MotherboardJumper: Almost allmotherboards contain a jumper that can clear all CMOS settings along with theBIOS password. The location of this jumper varies depending upon themotherboard brand. You should read your motherboard manual to check itslocation. If you don't have the manual then look for the jumpers near the CMOSbattery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS,etc. When you findthe jumper, look carefully. There will be 3 pins and the jumper will be joiningthe center pin to either left or right pin. What you need to do, is remove thejumper and join the center pin to the opposite pin. e.g. if the jumper joinscenter pin to left pin, then remove it and join center pin to right pin. Nowwait for a few seconds and then again remove the jumper and join the center pinto left pin. Make sure toturn the PC off before opening the cabinet and resetting the jumper. By UsingMS DOS Command: This methodworks only if you have access to the system when its turned on because thismethod requires MS DOS. Open Command Prompt from Programs menuand provide following commands one bye one: Debug o 70 2E o 71 FF quit NOTE:The first character in the above commands is English alphabet "o"and not the number 0. After providing the above commands, restart your systemand it should reset the CMOS Settings along with the BIOS password. If you arecurious to know how it works? then let me explain the above commands: In this method we are using theDebug tool of MS DOS. The "o" character present atfirst in these commands, outputs the values to IO ports. The number 70and 71 are port numbers which are used to access CMOS memory.By providing FF value we are telling CMOS that there is aninvalid checksum and it resets the CMOS settings as well as BIOS password. By UsingSoftware: There are a few software which canalso reset CMOS settings or BIOS password or both within a few clicks. But asstated above you should have access to a system which is turned on and shouldhave access to MS DOS or MS Windows: CmosPwd By Using Backdoor BIOSPassword: Some BIOSmanufacturer put a backdoor password in BIOS which always works irrespective ofwhat password you have set in BIOS. Its a master password which is used fortesting and troubleshooting purposes. AMI BIOS Passwords: A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD AWARD BIOS Passwords: 01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
J64
J256
J262
j332
j322
KDD
Lkwpeter
LKWPETER
PINT
pint
SER
SKY_FOX
SYXZ
syxz
shift + syxz
TTPTHA
ZAAADA
ZBAAACA
ZJAAADC PHOENIX BIOSPasswords: BIOS
CMOS
phoenix
PHOENIX Misc Common Passwords: ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj Other Manufacturer BIOSPasswords: Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin NOTE: All thesepasswords are case-sensitive and are changed from time to time bymanufacturers.
Posted on Mar 03, 2011
Don't know password P19S how to reset
Are you trying to reset the Windows password or a BIOS password? Linux Live CDs can help with the former. Need more details for the latter.
ChiJoan in Reno
Jan 25, 2014 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
It start beeping until XP window come up,
It could be a bad memory module. Try removing and reinstalling them. Try one module at a time to see if beeping stops . Check all other connections to make sure they are properly connected. Hope this helps.
Jan 01, 2014 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
I have the dell drivers and utilities cd but cd-rom won't boot
hi all u have to do is connect the PC to the internet and go to control manager and scan each device it will automatically install them.
If not i suggest u download cupid cpuz and you'll see all the info about your PC then Google each device and download them
Dec 21, 2011 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
HOW TO REMOVE BIOS PASSWORD IN DELL LAPTOP PP19S
Hi rkscompute481,
You need to contact Dell to get the Master Password for the BIOS. Just make sure you have your laptop with you when you call as they will ask some information/codes from it before they provide the master password.
I hope this information is useful.
Mar 03, 2011 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
My wireless on my Dell Inspiron Mini 10 has never
Your Dell may not have the wireless card driver installed.
Install the latest wireless driver.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
To setup your wireless router and the wireless card in the Dell, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 05, 2010 | Dell Inspiron Mini 10 Notebook
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron Mini 10 10v 1010 1011 PP19S Series Laptop Auto Car Adapter (C1930SUU3170B473B3) Logo
1,016 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
