Question about Sony KP-57HW40 57" Rear Projection Television
Overpoewering red my set came from my mothers house when she passed last fall. I never plugged it in until now. when I turn on the set everything is fine for about 8 seconds. then the red just starts to look like a super nova and then everything turns red. I can still see the picture but i cannot see any other color because the red is dominating everything. I can turn the set off and turn it back on and then the same thing happens all over again. the longer the set is off the longer it takes to happen again. sometimes it can take up to 5 minutes to mess-up. I took the back off and cleaned the lenses then i took a can of compressed air and blew out all of the dust nothing improved can you help me straighten out this problem
  • ripperjtl Nov 04, 2007
    My tv is doing the same thing. The person I got it from told me it only needs a new bulb, but I'm not sure if that is the solution.
  • lschwer2 Feb 03, 2008
    same thing happened to my 53" . got the tv fixed and the tech says it needs a green bulb for 400.00 . i dont want to spend that much. any ideas where to get a bulb for cheeper. its a kp-53hs10.
Every person I know who purchased this very expensive unit has had this problem early in the life of the TV. Sony is no help. Sony will suggest you take it to a repair facility. Sony from years ago is not the Sony of today. It was expensive to purchase and it will gouge you with repairs. Your choice. I eventually discarded my set and purchased a JVC. These rear projection TV's are garbage and Sony knows it and they dont care. Seems like the last for only a few years and then major problems occur. My solution replace it!
Posted on Aug 06, 2007
Pass word had been created on my ipad cannot get into !
There is only one way I know but you will lose everything up until the last time you backed it up ok turn it off after its off connect the cable to pc or laptop first make sure ipad still of ok then press and hold the home button don,t let go now plug in charge cable keep holding home button until you get the connect to iTunes symbol on the ipad if iTunes doesn,t open then click on it you should now see iTunes has detected it in recovery mode just click on restore or restore and update
Apr 22, 2014 | Apple iPad Tablets & eReaders
My fedder azhp12d2a portable air conditioning unit will not turn on, the light above where it says "built in three minute cooling delay" is blinking red continuously. When I plug it in it beeps and...
every time when you turns your ac on it takes 3min , dear it is just a time delay to protect your ac comp , it is not harmful. You can by pass it by pressing turbo key in remote aur by switching off your ac by remote only not by mains. it is helpful , try it
Oct 14, 2013 | Heating & Cooling
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
It wont turn on
make sure the wire from your start button is wired into mother board if this is a new build if its not a new build please post more info on problem you will get a better answer thanks
Oct 16, 2009 | HP Pavilion M9040N Elite Desktop PC
Electric Bosch tankless water heater wont heat water.
Here is the run down>
Water too cold Neon light on:
Cause:
1). Water flow is too high-adjusting the water flow as follow; open fully both inlet and outlet shut-off valves at the heater, then turn on fully the highest flowing hot water faucet closest to the outlet connection. Adjust the outlet shut-off valve until the water flow from the hot faucet corresponds to the approximately 3.6gal/min at 105 degree.
2). One of the power supplies is not on-check the breaker box, there should be three ganged breaker, each corresponds to each of the heater power supply.
3). The power supply voltage has dropped-reset the breaker in the breaker box.
4). Temperature dial is turned too low- temperature adjustment is made using the dial on the bottom edge of the unit. The adjustment is between approximately 95 and 135 degree F. Turning the dial clockwise increase the temperature settings.
5). The inlet water temperature has dropped-readjust the temperature dial.
Attached link is for Bosch hotwater heater installation. This should give you idea as to what to look for.
http://www.boschhotwater.com/Portals/7/TechManuals/AE115_AE125_English.pdf
The following link is Basch Hotwater troubleshooting Q&A, this should also give you some help.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/PowerStarModels/AE115AE125/Troubleshoot/tabid/632/Default.aspx
Please post back on this thread, If you still having problem.
Jan 27, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
95 Honda Passport Heater/AC Fan stopped blowing
Fan motors are vulnerable to junk falling into vents, fluff and debris being sucked in with air, as well as mice dragging nesting material in and setting up house inside squirrel cage. THis happens alot. Also, fans usually have a clip of some sort that has been added at one spot around the edge to balance the wheel during rotation. If this clip falls off, or an object causes a crack, or debris falls into the fan housing, the resulting imbalance will make noise! Fans are also easy to remove and check for trash or damage. Remove the fan motor and inspect for these or any other faults. COuld be a worn shaft bearing that's causing the vibration or rumble. Should be able to lay fan in floorboard, plug in and turn on. Hold the edge of the fan to stabilize it, and observe its operation out of the housing if no defects are found visually. Hope this helps you. TT
Nov 24, 2008 | 1995 Honda Passport
Tv comes on then instanty goes off red light flashes 5o inch flat
I've seen this before and found that by plugging the power cord into a different circuit in the house worked. Or you could unplug everything else and then try to turn on the tv.  If it comes on plug one thing in at a time until the tv shuts off and then you'll know how many things you can plug in at once.  If this isn't the prob then it may be a something in your tv that is pulling 2 much current and shutting it off.
Oct 18, 2008 | Audio Players & Recorders
Red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Aug 07, 2008 | Intel Motherboard
Sony KP-57HW40 57" Rear Projection Television Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
