Question about Kitchen Ranges
Water and debris in flue liner of Jotul Stove
We have a Jotul Woodburning stove on which we burn dry, well seasoned wood. Gases go up through a stainless steel flexible chimney liner and the stove draws well and burns well. The chimney is capped with a metal cowl to keep birds out and prevent rain pouring down.We find that bits of black debris drop down the steel liner and need emptying frequently from the base of the liner. This is easy to do, but the big problem is that sometimes if the stove has not been lit for a few days there is also an accumulation of black liquid at the base of the liner which smells of tar. The house smells dreadful. This happenend recently when we were away, and neighbours tell us there was no rain during our absence.The chimney through which the liner passes is built of thick stone. We have tried three different designs of cowl covers in the belief that driving rain may have been the problem. None have fixed the problem. Gases exit the burner at the rear and then pass through a right angled bend to rise vertically through the liner. Water and debris collect in the sump at the base of this right angled connection. Can anyone suggest what is wrong?
    Genius:
  • 1,036 Answers
You should have a swept T connector at the base, with the sweep going from the stove upwards, but the other end of the T going into a removable cap - or very short length of pipe. If you only have a standard bend - replace it with the T.
This is actually normal for wood burners. In an unlined chimney, the lighter "tar" fractions from the wood would soak into the brickwork, and show through the wall in a few years. In a lined system - they have to go somewhere, and usually condense inside the flue - running back down to the base.
The "chinese hat" style cap is actually very good for everything except sideways hail.
Sorry - but it's the nature of the fuel. It is possible to use a clay based absorbent at the base - Cat litter is actually fine.
Posted on Jan 03, 2009
How do I use a Jotel 1 stove
Google: Jotel 1 stove
This comes up with tons of answers including the instalation and user manual. If you are burning wood be sure it is dry and also pine can cause pitch build up in the flue so keep it clean or it will eventually catch fire and burn itself clean along with the building it is in.
Dec 13, 2014 | Kitchen Ranges
Black smoke coming out oven when cooker and oven on at same time
sounds like the debris from previous cooking is burning. I would suggest cleaning it first. If it's not happening when one or the other is on it might be because what ever is in there is burning at a higher temp. or two it could be that the element is getting too hot and is burning the metal itself. How old is the oven, what kind and cooker? do you mean the stove part? if it's the stove part there might be a leak from the top into the stove -older stoves - the back left burner also got heat from the oven. when cooking you could but a pot or pan on it and not have to turn it on.
Nov 28, 2014 | Kitchen Ranges
Can mulberry boiler/stove version be used without being plumbed in , or will heat damage dry boiler
fill the boiler with dry fine sand.that way it can be hoovered out if you need to connect it later. dont run it dry
Feb 21, 2010 | Kitchen Ranges
I have a quebb master multi fuel fire/stove it has a top flue pipe fitted how can i gain access to the flue to enable chimney sweeping
Hi Davebingj, It is quit simple to solve this problem. Inside your Quebb is a removable roof. You can lift up the roof a small bit, fold it together and pull it out of the front door. Then you have full acces to the flue pipe at the end of the stove. With the sweeping gear, which can bent easily, you can sweep the chimney very good because the sod coming out is staying inside the stove and doesn't sweep aroun the room. Hope this will help. If not give me an mail at: marbert2@eircom.net Hubert.
Jan 02, 2010 | Stoves Kitchen Ranges
When we lite up the wood burning stove the smell and the fumes are really strong the fires has been lit about 6 times any help?
the chimney pipe most be the same sides all the way out , it can not begin big and then small as it goes out. that's the problem with, your wood burning stove. it can be small and then big but not the other way around.
Dec 07, 2008 | Kitchen Ranges
We have a problem with our woodburning stove we get a lot of downdraft and not enough draw . Carole
hehehe i can know what that is like....
Is it a slow combustion heater? What sort of wood are you burning
Nov 05, 2008 | Kitchen Ranges
What is the minimum distance you need at the back of woodburning stove
thats gonna depend a few different factors, your stove manufacture will give you their minimum requirement, and then i would ck with the local town codes.
Oct 26, 2008 | Stoves Kitchen Ranges
Kitchen Ranges Logo
155 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
