My laptop not charging
Not charging up wen put universal charger to charge up
    Novelist:
    Champion:
  • 233 Answers
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Posted on Nov 01, 2012
LaptopExpert
  • 458 Answers
SOURCE: my laptop stopped charging
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
Posted on Jun 04, 2008
  • 36 Answers
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
Posted on May 23, 2009
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
  • 193 Answers
SOURCE: Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Posted on Aug 14, 2009
Testimonial: "Confirmed my theory. ^_^"
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
IBM Thinkpad X60- Charging LED ( Amber) flashes continuosly- battery NOT charging
An incompatible charger could be doing this, as could a failed battery charging circuit in the notebook. It is also possible that the battery is no longer capable of accepting a charge. The universal charger must be able to provide the same voltage as the original charger and have an equal or higher rating for wattage or current.
Feb 08, 2013 | IBM ThinkPad X60 1706 Laptop Universal AC...
Targus charger wont charge laptop when laptop on?
The laptop does not recognize the charger due to a different wattage/ amperage or is not powerful enough to charge the laptop while the machine is powered. I have seen many problems with hps/compaqs and the Targus Universal Charger and recommend the HP universal charger for those models instead.
May 23, 2011 | HP Compaq nw9440 Notebook
Computer wont charge with universal charger
Please check the technical specifications of your computer charger and see that your universal charger fulfills the same. Generally it is found that the universal charge may supply the required voltage but may not provide the required amperage. That is the reason most of the electronic companies insist on their chargers. If your charger is not working please get one from the company rather than using the universal charger and the spoiling your computer. Universal chargers are OK for some of the electronic devices which do not require higher currents.
Dec 27, 2010 | Dell Inspiron 1525 Laptop
Hey my samsung laptop fell on the floor wen i triped over the wires and it landed were the charger puts its thing in but the charger was in a the time and now it wont stay inside it looks loose or broken...
Probably broken the nipple from the cable which goes into the laptop, and starts it charging. pull it out and inspect the nipple on the charger see for any breakages, if it has snapped etc then it will require a new charger.
If it hasn't then it will be a broken inside the laptop, best thing you can do is strip the laptop and have a look or take it to your local computer repair shop, and it will be sorted...its a common problem with laptops the charging damage.
Thanks.
Wellyturbo.
Oct 23, 2010 | Computers & Internet
Blackberry 9530 touch screen does not function
If the problem occurs while charging with the wall charger then try changing the wall charger.
Jun 08, 2010 | RIM BlackBerry Storm 9530 Smartphone
My laptop in turn on but not charging and i turn off charging
sounds like you have replaced the laptop charger for the laptop to a universal charger and not an original.
May 27, 2010 | Toshiba Satellite Pro L300 Notebook
Aug 14, 2009 | Umax ActionBook 333T Notebook
Memory upgrade
if the problem sounds as it seems, you need to take the ram that you put in out, see if it turns on. if not, you may need to replace the battery. the laptop will not work on the charger itself, that ay be the problem.
Mar 22, 2008 | Toshiba Satellite L10 Notebook
CHARGER
I assume by charge you mean your power adapter. If this is the case you can purchase any universal power adapter for laptops within an acceptable wattage for your laptop computer. You can either visit your local best buy or circuit city store or purchase one at newegg.com. http://www.newegg.com/Product/Product.aspx?Item=N82E16834999586&Tpk=N82E16834999586 Hope this helps. :)
Oct 05, 2007 | Gateway M305CRV Notebook
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
