Question about Coleman Powermate Powermate 5000W Generator
How to rewind a stator coil in a powermate generator
4 Suggested Answers
protek480
  • 1723 Answers
SOURCE: powermate pm0545212.02 wont generate
The exciter coil can be checked with an ohm meter. It will read fairly low ohms (probably under 100). There are diodes also. You can check them with an ohm meter too. They should read in one direction only. The red lead on the meter is + and that will conduct through the diode when your on the anode. When you reverse the leads of the meter, it should read infinite or OL.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
protek480
  • 1723 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
  • 342 Answers
SOURCE: I have a PMC543250 Powermate generator. It just
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Posted on Apr 04, 2010
I have a coleman powermate maxa 5000 generator model pm0525312 that needs a rotor assembly replacement. The rotor is not passing a continuity test. The rotor is 5.0 kw rf5 model 0049621.
This shows the rotor as obsolete and I'm guessing the stator would be too. Stators are in the $200-300 price range. Probably better to just buy an new generator. Jack's Small Engine shows some stators but not your P#.
Powermate PM0525312 Generator Parts
https://www.jackssmallengines.com/Products/POWERMATE/Rotors-and-Stators
Sep 30, 2017 | Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Stator got hot on my generator
Stators can get hot, but not too hot? how much are you talking. This is indicative of a short in the output wires, and / or overloading with inductive loads. Compressors, motors, fans etc
Apr 10, 2013 | Coleman Powermate Powermate 5000W...
240 volt output of 3500 watt powermate generator measures 140 volts
Bad capacitor in the alternator field or a short in the rotor / stator
Nov 05, 2012 | Coleman Powermate Powermate 5000W...
How to test stator
You will need a very high quality ohm meter that can account for test lead resisitance. Stator wire leads are ohmed right off the stator and their value is generally low 0.8 or less ohms (each generator model and windings is different) and needs comparing with a specific model factory service manual. Temperatore also affects this reading. Often best left to a pro with a low impedendance meter or a device called a wheatstone bridge, as the resistance is often too low to see on a conventional meter
Aug 04, 2012 | Coleman Powermate Powermate 5000W...
What is the stator
The stator is the outside part of the generator with the windings. The rotor is the part that turns inside the stator.
Robert
May 11, 2012 | Coleman Powermate Powermate 5000W...
No output coleman powermate pm401211
Check the capacitor first,check rotor diodes, rotor and stator for shorts, and brushes
Oct 27, 2011 | Coleman Powermate Powermate 5000W...
check
Feb 16, 2010 | Coleman Powermate Powermate 5000W...
Checked capacitor, diodes and circuit breakers and all check out ok. Still no output voltage. Excited with 12 volts across brushes. Still no output voltage. Took the head off and check field windings which...
Make sure it is not the brush set.
There must be continuity from one slip ring to another.
If not, but rotor doesn't look burnt - check points where rotor wire is soldered to slip rings, or clear contact point on each side of wire and check continuity there, past slip rings and brushes. Big chance that wire came loose from slip ring.
Had such problem on my Champiion 3500
evern if burnt - rotor is easy to rewind at home, unlike stator.
Unless your model is Inverter type - there is AVR module.
But, unless your rotor has continuity - don't bother going further.
Jan 13, 2010 | Coleman Powermate Powermate 5000W...
Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Aug 16, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
