Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
Wake Up Timer
I set the wake up timer but I am not sure how to set the time back to "0" so the tv will not automatically turn on when I am not home.
  • Anonymous Jan 03, 2009
    I cannot turn off the wake up timer either. There is no button for it on the remote. No matter what button I press it will not go to --:-- It's always at a time. Can someone help me please?
U have to set real time first then set the desired time when u want to on ur tv and standby the tv via remote,
Posted on Jun 13, 2007
Why? Jvc sound bar turning in by itself, no one turned it on, three mornings in a row , turned on radio automatically???
It sounds that you have accidently set up an alarm setting that is set to wake you up in the morning!
Look in the manual and see what it says about timer settings.
Aug 21, 2016 | JVC TH-BA1 Soundbar System with Wireless...
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
Mar 11, 2016 | Televison & Video
37LG50 turns on automatically.
Welcome to FixYa.
Check the Wake-Up timer settings of the TV. The TV may be set-up to turn on at a specific time or time intervals. Go to the timer settings of the TV by accessing the timer option from the MENU.
Thank you for using Fixya.
Jas247
Aug 29, 2011 | LG 37LG50 37 in. LCD HDTV
My tv keeps turning on and off by itself
Tv has a features for wake up timer and sleep timer. Try to check this setting maybe the time for wake up and sleep is already set to it.
May 09, 2011 | LG 26LG30 26 in. LCD TV
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
On timer light is flashing.and tv shuts off in about 5 seconds after turnig it on.
Hello
Timer function is in ON position and have been set to the least time I thinks. You just go to the menu and put the timer fuction of OFF.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
Dec 06, 2010 | JVC AV-27D302 27" TV
Does this tv have a clock where I can set an alarm to wake me up in morning but it automatically turning on tv?
No it doesn't. It has a timer setting allowing you to turn your TV OFF in a certain amount of time, in 30min increments. But it has no setting to turn your TV on.
Dec 24, 2009 | Sanyo DP32649 31.5 in. TV
How do i turn off the wake up feature
Press MENU to bring up the TV Main Menu. Select the Time menu. Select the Wake-Up Timer. To clear the wake-up timer, display the
wake-up screen and press PRESETS.
Jul 07, 2009 | RCA E13332BC 13" TV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
575 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
