Question about Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive
How to eject (exit) from nomad mobile desktop program/acomdata e5
We have a 500 GB external hybrid drive from acomdata. This is a high speed usb 2.0 type. The problem is that the window or screen for the nomad program is not showing the eject button or the "tour" button at the bottom.  It is as if it has been cut off. To make sure we don't cause problems with the computer or the acomdata device we need to know how to shut things down properly.  When we began installing this device on the computer last night, some of the screens were supposed to have a place to click "ok" but they didn't .  Hitting "enter" got us through .
  • 3 Answers
Have you tried changing your display size for you computers desktop?
Try a higher resolution first, then if that doesn't work try a lower resolution.
Most like the items are there and your display resolution is the problem.
Posted on Apr 21, 2009
I would like to know the DC voltage for my 250 GB acomdata drive? Thanks!
http://www.ebay.com.au/itm/HI-SPEED-USB-Cable-Cord-Acomdata-HD080UFAPE5-72-HD080UFAPES-72-Hard-Drive-HD-/350553798345?pt=US_USB_Cables_Hubs_Adapters&hash=item519ea276c9
or
http://www.ebay.com.au/itm/USB-2-0-PC-Data-Cable-Cord-Acomdata-External-Hard-Drive-Enclosure-as-image-/271054572490?pt=US_USB_Cables_Hubs_Adapters&hash=item3f1c1c8bca
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Oct 08, 2012 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
My acomdata 250 GB freezes and does not allow files to be copied and or moved back to desktop computer or to new files within the 250 external drive
there are three main reasons for a hard drive to freeze
up 1. you have reached the capacity of the drive or 2. the drive heads are worn to the point where the drive can not boot up to the PC , meaning the heads need
to be replaced 3. the interface between the unit and
the PC 2.0 high speed will not work into a 1.0 USB
then you have several minor things that can happen
like the degeneration of the cables that are being used , a quick remedy is to go to my computer
right click on the drive compress the drive to save space then do a clean on that drive and also sometimes the HDD needs to be reformatted .
Jan 15, 2010 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
I have a model HD320UHE5-72 external acomdata hard drive that when pluged into usb and power turned on is not reconized by computer. Vista It worked fine until yesterday.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 18, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
File transfer
Try turning everything off and then replugging the drive in.  Then start your computer back up/turn drive back on (if you have to).
Jan 31, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Missing power cable and
Any 12 volt dc 750ma+ power adapter will work.Install the right plug on the end for your external drive. You can go to radioshack and they will have the proper end for your drive. You have to make sure the polarity is right though as it's direct current. The tip or center must be positive. I recommend testing this with a volt meter before plugging it into your drive to ensure proper polarity. I hope this helps you.
George
May 13, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Acomdata 160 GB
Please reinstall your windows your windows may be crroupted
Dec 08, 2007 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive Logo
403 people viewed this question
Top Acomdata Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
