Question about Garden
Spare Partys for AL-KO Hurricane 2000E Blower Vac
Fan/Blade Part No. 407954 Broken Require New one
2 Suggested Answers
SOURCE: replacement bag for sovereign blower vac
Balmers Garden Machinery. Burnley Lancs.
Tel 01282 453900.
Have these bags available,
Posted on Dec 11, 2008
Al ko hurricane 2000e manual service
Index of AL KO Laubsauger maybe one of these scamatics will help
May 02, 2014 | Garden
Black decker manuals
First I would check to see if the wood chip is not obstructing the fan blade. If the fan blade turns freely and the motor still does not start, you will need to open the unit and check to see if your getting 110V A/C going to and after the switch using a DVOM meter. (Digital Volt Ohm Meter). Wear insulated gloves since you will be working with 110V. Use extreme care when probing the circuit. Before plugging the blower in after it has been dismantled, disconnect the fan motor wire to prevent accidental start up incase a connection is made. If there is power present before and after switch, check to see if the fan motor is getting power from the switch. If there is power present at the fan motor, then you have a open circuit in the field winding in the motor. If that's the case, Sears has a nice on line parts directory that covers many appliances including your blower. You will need the make and model number off the case of the blower to input it into the system. Good Luck and hope this was informational.
Jan 04, 2014 | Black & Decker Leaf Hog Blower Vac With...
Broken pull cord mac320v leaf blower
The pull string is in a housing underneath the fan. Remove the left (as you're holding the blower with the outlet facing away) housing. The blower fan is visible. Use a 1/2" light duty impact driver, it's a conventional clocking leftie loosie rightie tightie. Remove nut, thick flat washer, fan, and another thick flat washer. Three screws are holding the pull string housing. Remove the housing. Three more screws and thin flat washers, and the spool is in your hand. Reassemble in reverse order.
Apr 15, 2013 | Homelite Consumer Products Backpack...
Blower motor thermal cut off
Obviously, you are talking about your vintage 1932 Chevy Coupe. I know that's the vehicle because you did NOT say that it WASN'T!
The fluttering sound is probably dry leaves that got stuck in the blower assembly! Suck them out with a shop vac!
Apr 29, 2017 | 2000 Chrysler Town & Country
Would a broken blade on the impeller cause the motor to becomeexceptionaly loud?
You probably bought a new one by now.Nov. 2011.
If the broken chunk was sucked into the motor? Yeah.
Nov 29, 2011 | Toro Blowers Rake and Vac - Electric...
Blower motor vibrates really bad, the faster the fan the more vibration
piece broken on fan blade of heater or it is warped. probably will have to replace unit.
Feb 05, 2011 | Ford E-250 Cars & Trucks
Hi I am Armando and I have a LG AC Mo # LSN180CE and I start to hear a bearing rattle noice right after the compressor, seems to me like it. The evaporator is like 20' o 25' away inside of the room, the...
First of all confirm where the sound comes from whether from Indoor or out door. If from indoor, the blower bearing worn out/ blower wheel broken.
If from out door, fan blade broken (replace fan blade)/compressor internal sound(replace compressor)/compressor seating bush worn out.(replace new bushes).
Helpful.
Jan 21, 2011 | LG LSC121PMA Split System Air Conditioner
My blower is running extra high and hard. so high that it shakes the cap off. how can i tame it down. model 51587
Remove the bottom of the blower or vac and see if any blades are broken on the plastic fan blade, known as an impeller. If a blade is sheared off, this could be the source of your noise and shaking. This part will need to be replaced. I've just ordered one and will be replacing mine when it comes in.
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
Has no suction
I just went through the same thing.  Your fan or impeller is probably broken off the shaft and no longer on the motor shaft.  My local repair shop wants $9 for the impeller and $29 to replace it. You will have to take the thing apart and put on a new fan or impeller blade and I'm still trying to do that to my vac.  I think I will have to heat the nylon impeller with a hair dryer to get it onto the shaft and then tighten the left hand nut. My vac is held together with torx screws so add a torx screwdriver to the price if you don't have one and want to do the job yourself.
Aug 19, 2007 | Eureka Whirlwind 4383 Upright Vacuum
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
