Question about Casio Watches
How do I reset time on Casio A168 watch - Casio Watches
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 05, 2009
escapement
  • 2334 Answers
SOURCE: reset time and date on my casio wvq-550 watch
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Posted on Apr 08, 2009
  • 65 Answers
SOURCE: need to reset time and date. its a casio wrist
Check out the manufacturers web site, some manufactureres have users manuals for their watches which can be downloaded. You may be lucky. You could also try some of the various manuals websites. They have manuals for all manor of things. Good Luck
Posted on Jul 22, 2009
  • 2501 Answers
SOURCE: The brand new Casio watch
Assuming all Casio models have the same mode of operation, try this:-
Press the mode button until you see "HS" on the display (hand setting) and then use the 2 and 4 o'clock buttons to adjest the hands.
If this does not work and you do not have the manual for your watch,you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
y
Posted on Dec 24, 2010
How to reset a casio g shock watch
HOW TO set your time on a G-Shock watch - YouTube
? 0:56
https://www.youtube.com/watch?v=_cwKYE1JMXM
Apr 8, 2013 - Uploaded by JseanSSent
This is a how to video on setting your G-Shock. ... Casio GSHOCK GA110GB-1A REVIEW ' How To Set Time ' LIGHT DISPLAY - Duration: 2:59.
Reset gshock - YouTube
? 1:41
https://www.youtube.com/watch?v=s6XVUqui6Nw
Jun 7, 2014 - Uploaded by aswan yusof
Tutorial how to reset gshock after changing battery. ... Reset gshock .... GA110-1B Stealth Black Casio G-Shock WatchReview - Analog DIgital ...
Dec 29, 2015 | Casio Watches
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
Jun 10, 2014 | Casio Pathfinder Watches
HOW DO YOU REPLACE A BATTERY ON A CASIO 1572 A168
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
Chris
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.
Feb 26, 2013 | Casio A168W Wrist Watch
The brand new Casio watch Module No. 2747 does not allow the analog time to be decreased! I've reset the digital time to the present time. When I try to reset the analog time (watch hands) I cannot turn...
watches;
Accept terms
y
Dec 23, 2010 | Watches
Reset time on casio g shock
Click on my profile and browse through my tips and tricks till you find link to all Casio watch manuals. Use that link and follow instructions. Rate me, please.
Jul 05, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Lost manual can't reset time or turn off alarm
Hi Cheese,
Please use the link below which has the information to reset the time
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw5057.pdf
May 14, 2009 | Casio Watches
I need to change the time zone and thus the time to EDT
http://www.generalmanual.com/Watches-Clocks/Casio-WV57HA-1AV-Waveceptor-Watches.htm
find the manual here and download
Apr 11, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Reset time and date on my casio wvq-550 watch
Follow this link:
Rate me, please.
Apr 08, 2009 | Casio Executive Wave WVQ550DA 1AV Watch
Reset time on Casio G Shock
how to set time on my g-shock watch dont have my manaual.
Nov 02, 2008 | Casio G-Shock G2600 watch
Watches Logo
236 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
