-   I have the same problem. after cleaning...same problem...someone told me it's the thermocouple....-   Guest
Mar 01, 2009
-   Same here. I've used it less than a dozen times in 8 months. Now it won;t stay lit for more than 5 minutes. What's up with this? Help!
-   diverdown61
Mar 01, 2009
-   Same here. I've used the heater less than a dozen times in 9 months. Now it lights but goes out after 3-5 minutes. What's up with this?
-   Guest
Feb 27, 2009
-   Low burner stays lit for one minute and then goes out. Full tank of propane. Very frustrating! Probably the last time I buy Charmglo anything.-   Guest
Feb 09, 2009
-   My heater lights for 3 to 5 minutes then just goes out!!!!!!!!!!!! any suggestions?-   buckeye7
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and...
(More)
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and flame works, but no heat. Unit only worked for a few times, then this happened. How can I troubleshoot to see what part needs to be replaced. Thanks.
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but...
(More)
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but neither pump works. Both fuses are good. Electrician just checked them. No reset on pumps. Any ideas?
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve...
(More)
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve problem ?
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with...
(More)
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with a slight hissing noice but the smell of propane is very slight. The propane tank is full and functional and I have cleaned out the top section where the gas is emitted. Has the regulator gone bad or is there another issue?
