Question about Home
Have old Twyford leaking toilet cistern. How do I turn off water
Cant find a valve in bathroom to cut off water supply to the toiler cistern
  • 68 Answers
SOURCE: toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Posted on Dec 27, 2008
  • 7 Answers
SOURCE: Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Posted on Feb 02, 2009
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
olddewsons
  • 38 Answers
SOURCE: Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Posted on Jul 07, 2009
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Low pressure cold water tap in bathroom washbasin
It's a common and acceptable practice to have both on the same line, typically 1/2" copper or pvc. I wld start by checking to see if the valve under the lav is turned on all the way. Also, check the screen on the lav faucet. With a pair of pliers just grab it lightly and twist clockwise as ur looking down on it. Sometimes when the water is turned off for whatever reason and turned back on sediment will be jarred loose and get trapped in the screen. When the toilet is not being used the extra pressure will be enough to get a normal stream, but if the pressure drops a little u will see a noticeable reduction in water flow.
Jun 09, 2010 | Plumbing
We used to have a separate toilet next to the bathroom. When we have the loft extension built the WC was relocated to the bathroom to make way for the new staircase. Since then we have very low pressure...
The water all comes from the same place usually. What you need to check is your supply line to that area the supply should be larger than the feed lines, depending on the code in your area. The supply carries more volume to your usage areas that's why it should be larger, then you tap off of the supply with smaller pipe to connect feed lines to receptacles. To long of small feed line runs lead into problems maybe such as you have. Was the job inspected by your town or local agency? They might have caught such a discrepancy.
Jun 08, 2010 | Plumbing
My toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Oct 17, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Water overflow from cistern to bowl after flushing the water keeps going into the bowl where is the water shut off valve on these toilets?
The shut off valve depends upon where your plumber fitted it and whether one was installed at all. If there's not one near the cistern then you'll need to find the stop valve which is on either the main household cold water tank outlet or if the cistern is filled directly by mains water then you'll need to turn off the main supply valve or even the valve in the street.
The fault is caused by a failed syphon assembly inside the cistern. Although it's possible to remove the faulty part and replace it the sheer number of different syphon assembly designs and the age of many of them usually mean that it's quicker and simpler to replace the entire assembly. Without knowing exactly which make and model of syphon you have it's impossible to give you any more specific details as the operating methods vary so widely, but if you're mechanically minded then you may well find that you can dismantle the old syphon and locate the failed seal. Sometimes all you need to repair them is an old car tyre inner tube and a pair of scissors. A repair often costs pennies and takes hours, a complete replacement syphon assembly often costs between £13 and £60 depending on the model and design (plus labour) but usually takes no more than around fifteen to twenty minutes to replace if the cistern is close-coupled to the toilet and a bit longer if it's an old-fashioned high level cistern with restricted access.
Given the need for guesswork based on the limited details in your question I hope that you appreciate my reply and ask only that you return the favour by rating my answer.
Oct 01, 2009 | Home
Toilet cistern doesn't fill up
Apr 21, 2009 | Kallista Michael S Smith Country Elongated...
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
