Question about Cameras
Lens error when i turn on my coolpix S4 it shows lens error I have the same problem with my S3
  • 28 Answers
Bump the camera hard against the palm of your hand, or something harder if you dare. The lens is likely stuck. My Panasonic did the same thing. Knocked it a few times on the side of the counter and the lens popped out. Wiped it clean and it's worked fine ever since.
Posted on Jan 03, 2009
Turn on, displays : Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 26, 2010 | Nikon Coolpix S4 Digital Camera
Tip
Galaxy S4 I9500 LCD LCD Assembly
Appropriate for: GT-I9500, GT-I9505, SGH-I337, SCH-I545, SPH-L720, SCH-R970, SGH-M919
Regarding Samsung Galaxy S4 I9500 LCD Display screen and also Digitizer Assemblage Substitute : Sapphire
This kind of merchandise contains:
1. LCD Display screen;
a couple of. Digitizer Touchscreen display
When you examine Samsung Galaxy S4 Digitizer and also LCD display screen assemblage and also Samsung Galaxy S3 Digitizer and also LCD screen side simply by part, the most significant variation will be the outside ends with the S4 are usually seemingly more compact as compared to in which about S3. The particular size involving the side as well as the principal exhibit location is 1. 5 mm, not even half of the with the S3 helping to make a lot more area to match a more substantial display screen. There is certainly one more gap around the higher still left part with the Samsung Galaxy S4 which usually doesn't show up about any mobile phones just before it could be some type of sensor or perhaps a great DIRECTED notification
Once we turn over the 2 LCD display screen assemblies, we all can easily see the contract cable tv connectors around the a couple of monitors come in diverse opportunities, regarding S4, the particular contract cable tv will be at the top, but also for S3, the particular contract cable tv will be in the bottom.
Once we go through the display screen assemblage using this perspective, we could note that the goblet contact lens and also digitizer powering that are usually leaner in comparison to the particular S3.
Today let's have a look at the particular Samsung Galaxy Take note II Digitizer and also LCD screen compared with all the Samsung Galaxy S4 Digitizer and also LCD display screen. The particular Take note II can be a huge cell phone, the particular side across the display screen with the Take note II will be a couple of. 8mm, practically twice in which with the S4 as well as the Take note II provides a couple of contract cabling around the again although S4 simply provides a single. The particular fullness regarding Take note II is significantly plumper compared to the S4, specifically the particular goblet contact lens.
For Samsung Galaxy S4 GT I9500 I9505 I545 L720 R970 I337 M919 I9502 LCD...
on Feb 15, 2017 | Samsung Cell Phones
Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 03, 2009 | Nikon Coolpix S4 Digital Camera
Coolpix S210 Lens Error
I think I answered this one earlier. Is the lens stuck? If so, help it out with a little screw driver. Worked for me!
Dec 06, 2008 | Nikon Coolpix S4 Digital Camera
Lens cover error
I have a solution for Nikon coolpix S5/S6. I am not shure but it might be similar for S8, You can try my document "nikon s5 s6 lens cover error repair.doc"  uploaded on site
http://www.esnips.com/web/papputatiyasStuff
Regards
Mukesh
Aug 03, 2008 | Nikon Coolpix S3 Digital Camera
Lense error
Jun 21, 2008 | Nikon Coolpix S3 Digital Camera
I have a nikon Coolpix S4 camera tha will not show what the swivel lens is focus on.
I can't get an image on my coolpix L15 monitor screen, it just shows a bright light, it will snap pictures and show a flash , but no image
May 30, 2008 | Nikon Cameras
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Lens Error
Could be fatal - looks like it need to go to hospital- Nikon support Looks like CoolPix dont like that sort of Cool huh
Mar 08, 2007 | Nikon Coolpix S4 Digital Camera
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
