Question about Samsung SPP-2020 Thermal Photo Printer
Samsung 2020 photo printer
Print paper does not feed into printer
  • kudos68 Jan 18, 2009
    when i try and print, the paper goes so far in then stops, i know it feeds ok as when i turn it off it pushes the paper through where it prints.
  • Anonymous Mar 31, 2009
    the printer decides to turn itself off each time i try to pirint, it sounds like its going to do something then decides it doesnt want to
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
Can not install drivers for samsung photo printer 2020 since going over to windows 7(seven)
went to samsung web site typed in search box .....samsung photo printer 2020 64 bit ....downloaded instaled... then switched on p/printer and all was ok .....all becuse i changed to windows 7 64 bit... had the same problem with epson printer all in one( epson stylus cx32oo).... now all i need is drivers for microsoft sidewinder forcefeed back 2 JOYSTICK
Jan 22, 2010 | Samsung SPP-2020 Thermal Photo Printer
How do i use the blutooth on my samsung spp-2020 printer??
Enable the bluetooth function on the printer and then, on the bluetooth device (Like a cellphone for example) choose "Print via Bluetooth".
Nov 03, 2009 | Samsung SPP-2020 Thermal Photo Printer
The rollers in my samsung spp-2020 are sticking
On most printers there's a "thing" near the rollers that grabs the paper. It's usually a flat piece of plastic with some kind of stuff on it that grips the paper. It's actually on the out bound side of the printer. You can re-glue the pad by super glue if the part isn't available.
Jun 21, 2009 | Samsung SPP-2020 Thermal Photo Printer
Print cartridge
There is a green 'latch' just above the cartridge when it is installed. If you move this, the cartridge will release.
Best Wishes,
Karlos
Apr 12, 2009 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2020
You need to get the exact photo paper for this model.
The ones that comes with the flaps on each ends.
Without the flaps, the printer won't print.
Aug 05, 2008 | Samsung SPP-2020 Thermal Photo Printer
Paper won't feed on my Samsung SPP-2020
i had the same problem and replaced the ink cartridge and hey presto ! it worked
Mar 10, 2008 | Samsung SPP-2020 Thermal Photo Printer
Samsung photo printer spp2020
Apr 01, 2007 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2020 Thermal Photo Printer Logo
294 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
