Question about Lanier 5222/27 Laser Printer
Lanier 5627 feeding paper problem
The paper keeps getting jam between the drums.
5 Suggested Answers
SOURCE: Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Posted on Apr 08, 2009
santosj27
  • 263 Answers
SOURCE: lanier model 5627,fault code SC542 upon power up
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
Posted on Jan 22, 2011
santosj27
  • 263 Answers
SOURCE: lanier model 5627 with fault code sc542 upon power
LOL I think I already gave you a solution try this:
6. Turn ON
And thats it
santosj27
  • 263 Answers
SOURCE: What is the service mode for a Lanier 5627?
Why you continue to ask the same things? Why do you continue to put new posts? If you answer when I suggested that perhaps you have your problem solved.
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
My Brother MFC8220 Keeps jamming the paper as it starts to enter the drum, is this a feed issue? or a Drum Issue? It appears to feed from the tray correctly, but then starts jamming as it enters the drum.
Using a cloth damp with water clean the feed roller. You will see it when you pull out the paper tray. If it starts feeding good it was a feeding prob.. If it keeps doing it look at the leading edge of the jammed paper for any signs of dings or bends. if you find any paper damage look in that area for what is causing the damage. Thank you, Steven 805-520-3003
Jul 26, 2010 | Brother MFC 8220 All-In-One Laser Printer
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
MFC-7420 "Change Drum Soon" I have had this message for a while. I purchased a new drum. In the meantime the printer continues to print fine, except we have paper feed problems. Is the drum related to...
the only time i've seen the drum affect paper feeding is if paper jams in the drum unit. i would use your current drum until print quality decreases to an unacceptable level. it will not shut down, and you will not see a "change drum message." if your paper feed problem is centered around the cassette/paper pickup area, you can try cleaning your rollers with water and a soft rag, and also make sure your rear paper stopper in cassette isn't pressing too tightly against the rear of paper stack. best to leave 1/8" gap, otherwise paper will not lift properly to the rollers.
hth,
razors
Apr 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Apr 07, 2009 | Lanier Office Equipment & Supplies
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
Apr 23, 2008 | Lanier 1205 Copier
Paper jam problem on KXP7100
Typically, most of the time paper jams are caused by a defective photostatic print drum. When the drum goes bad and can no longer hold a charge, the paper sticks to the drum because the paper has a charge on it that attracts the two. There would be where I would look first. Now, if thats not it, the feed rollers could be getting worn. For a quick fix, take some fine sandpaper, and scuff up the rollers a little. This will create enough friction to allow the paper to feed through the printer smoothly. Keep in mind that using th sandpaper is only a stop gap measure. If the rollers are worn, they will need to be replaced soon. Hope this helps. Good luck.
Jun 20, 2007 | Panasonic KX-P7110 Laser Printer
43 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
