Question about Miele T1322C Electric Dryer
Dryer tripping electricity saftey switch
Hi I have a second hand Miele Dryer model T4450 (i think). It has been working fine, however after being on for a long time last night the clothes were still damp and the cycle stopped on cool down and didnt finish. Inside the dryer had quite a bit of water droplets. I emptied the water container and put the machine on. upon doing so it tripped the saftey switch and kept doing so on each drying cycle except the 15min cool down cycle. It also worked for a little while when the cooler temperature button was on, however after a while this too tripped the switch. I have used the machine aprox 10 times prior to this without incident. Any suggestions as to what is causing it to trip our electricity saftey switch?
  • 87 Answers
You probably have a shorted heating element.
Posted on Jun 08, 2007
Hi there,my (quite old) miele novotronic dryer all of a sudden trips out all the electrics when switched on, any ideas?please help!!
not safe to use
will need an electrician
not easy to get some parts for that model
possibles
plug to wall shorted internally
older the dryer more reduction of wet clothes load required
motor or bearings tired
timer or heater element faulty
safety door switch faulty
Nov 02, 2016 | Miele Dryers
Miele T4262 C - Not Drying. Hello, My Miele T4262 C is not drying. The light comes on inside and the drum rotates just fine, but it isn't heating up. Is there a 'reset' switch? If so...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 20, 2011 | Dryers
Miele T230C dryer keeps tripping out after only a few seconds?
Mostly likely cause is the heater element part no. 6138580. To ensure this does not happened again 1. Ensure appliance is situated in a cool room with ventilation (If room to hot it will not condense)
2. Ensure metal heat exchanger at bottom of appliance is rinsed regularly both long way and width ways.
Feb 01, 2011 | Miele Novotronic T230C Electric Dryer
Kenmore Dryer Model #68202 just quit working. Set
Hi and welcome to FixYa. I am Kelly
Things that will cause a dryer to just up and stop are:
1. Door switch
2. Motor Switch
3. Belt switch
The first thing to check is the door...
a. Verify the door remains closed and that if you gently tug on the door that it does NOT make the door switch click. Things like the switch actuation post get worn and clothes being dried press against the door and can cause the dryer to stop.
The second thing to check is the drum.
a. Reach inside the dryer and push the drum in either direction. If it moves easily with little resistance (Belt not turning the motor as drum is moved) then the belt has broken and the belt saftey switch has been activated causing the dryer to appear dead in all aspects.
The last thing that can cause it to just stop is a failure of the motor or motor switch. (Least suspects at this time)
Also go to the main Circuit breaker panel and physically turn off the dryer 30A Circuit breakers by pushing them against the off position and then back to the on position. This resets the breaker completely
You did not mention the age of this Dryer yet at this time I suspect a broken belt has tripped the belt safety switch.
Thanks for using FixYa!
Kelly
Mar 03, 2010 | Dryers
Thermal Fuse/No Heat- Where is it??
We were drying pillows and the thermal elements tripped. I took the panel off of the back of the dryer. The screwdriver uses a hex head (Lee Valley Tools). There are 3 thermal switches. Pushing the button at the center of each switch resets the unit. Our Miele is now running again which saves me a $200 service call.
Dec 11, 2009 | Miele T9800 Electric Dryer
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Dryer quit drying
if fairly new and element back 279816 is pt # for saftey element 279838 i think
Apr 24, 2008 | Whirlpool LER5636P Electric Dryer
Miele T1322C Electric Dryer Logo
325 people viewed this question
Top Miele Dryers Experts
Mike
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Miele Dryer Expert? Answer questions, earn points and help others
