Question about Dyson Ball DC24 Bagless Upright Vacuum
Hoover judders when pulling back as hoovering
2 Suggested Answers
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: i have a dyson 27
    Sorry to hear you're having difficulties with your DC27. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it might be worth using a little more force than usual, in case the upright lock mechanism has jammed. If this doesn't help, or if you're reluctant to try this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 10, 2011
    Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
    Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
    Oct 20, 2014 | Hoover Vacuums
    How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
    Click this to go to a site that will show you (complete with illustrations) how to change belt.
    http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
    I hope this helps.
    Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
    My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on,...
    There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
    Jul 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    How to clean my Hoover steamvac brushes? or
    http://www.hoover.com/pdfs/manuals/F5914900.pdf
    Press all four latches (B) and pull brush
    block out. The brushes can be cleaned
    under running water
    Godbless
    Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    My hoover steamvac spot doesn't spray
    the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
    Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
    Hoover sweeper model U4263-930 belt change
    undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
    thank you for useing fixya please rate me
    Feb 07, 2009 | Hoover Vacuums
    Need directions
    This is an older model Steam Cleaner. The upper tank, fill with hot tap water up to the fill line, then add 5 ounces of carpet solution to the water using the upper cap to measure. Make sure the lower letank is secured and turn it on, tilt the handle back, pull trigger to release solution to floor going forward, then release when pulling back slowly to extract. I am not sure if the manuals are available online, however you may be able to locate a Hoover dealer which may have a digital copy. They can be found through the hoover.com
    Jan 19, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
    Hoover model F8515 won' t **** up any water
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=703954
    Hoover Model F8515 won' t **** up any water
    posted by kevingao92 on Jun 24, 2008
    It could be in reverse do you have any tips
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Model # F8515 works on the pull back to pickup the water and on the push forward you can dispense extra water or solution and the brushes will still scrub but on the pull back it dispenses, scrubs and also picks up the water all in one sweep, if not then contact you local vacuum dealer in your area, check the owner’s manual for the trouble shooting guide and or call the Hoover Factory cust serv @ the information listed below.
    So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.hoover.com Telephone
    Contact our Customer Service Department at 1.330.499.9499
    Monday through Friday
    8 a.m. - 7 p.m. EST
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Hoover SteamVac
    My Hoover Steamvac won't puo=ll out the water when I try to cleean the carpet. What do I need to do?
    K758@aol.com
    Dec 30, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
    How to open the hoover DM4526 to change the belt
    there are normaly5screws 3in the front 2in the back remove these and the bottom should come off pull the brudh off repace belt on to brush put brush back in to seating pull brush on to drive and re,asemble
    Dec 06, 2007 | Vacuums
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    55 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
