Question about Lands Phones
TELKOM Apollo duo dect unit not charging
Second station charger beeps when phone is placed on it
3 Suggested Answers
SOURCE: VTech 2651 base (2.4GHz) +3 phones - base not charging, has power
email me, i may have a bbase for you, put vetech phone base in the subject line. thanks
tim
my email tpmtpm@aol.com
Posted on May 15, 2010
  • 3 Answers
SOURCE: Tesco ARC200 Cordless DECT Phone: Batteries will not charge.
A new battery is available from
www.espspecialbatteries.co.uk
Posted on Jul 21, 2010
Will not hold charge / shuts off
the batteries may need replacement. 2 aaa size ni-mh 560 mah 1.2 v are required. or the charger may be defective. If the charging light or the battery bars show up in display when placed in the cradle, the charger may not be defective.
Mar 16, 2015 | Uniden DECT 6.0 Cordless Phone ID
We have a DECT 122 - 3 hand set and base station. We have difficulty in obtaining a dial tone and unit screen on unit 1 displays the word "SEARCHING" on it. On the base station unit, the...
Hello Haggis,
This problem is with the batteries try removing them and let the phones sit for a little while... once you have done that put bats. back in and place on charger, if your still getting the error message do a reset under the advanced menu. If none of the above soultions work for you please contact me at fixya@whypayforhelp.org and i would be happy to get some more details from you and see if we can figure this out
~Lee
Founder of free tech associates
May 28, 2008 | Lands Phones
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
Do two handsets plug up to telephone line? If so how?
The main unit with answer machine has an inlet line where the phone line from the wall plugs into,which is located in the back of unit along with where the power cord gets attached. The second handset should have a stand/charger unit that should just plug into an outlet only to charge it. The two handsets run off the main answering machine/ unit. So as long as that is plugged in you should be able to use both handsets, because they both operate on the same frequency wave. Hope this helps you.
Apr 25, 2014 | Panasonic KXTG4731B KX-TG4731B KX TG4731B...
1 of my trio BT 1500 keeps beeping I have fitted new batteries
Try it in another charger as it sounds like it's not charging, solutions, clean battery terminals in phone, clean terminals on charger, swap chargers
Mar 28, 2013 | BT Hudson Plus 1500 Trio Dect Cordless...
Samsung s duos wont charge
even i have got the same problem. Its two weeks old and is not getting charged. I.ve tried both the regular charger and the usb cable to charge it. Guess will have to take it to the service station.
Mar 02, 2013 | Samsung Galaxy S Duos S7562 White Dual SIM...
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Need to know if there is an alternative charge method, other than the ac charger or battery packs
Get a docking station ( assuming it has the connectors for a docking station )
If not then you will need to get it repaired and any laptop repair place assuming they are valid should be able to assist with this.
May 02, 2009 | Computers & Internet
Cordless MX DUO charger
try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
Jan 10, 2007 | Logitech Cordless MX Duo 967300-0403...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
