Question about Orion HCCA-D5000 Car Audio Amplifier
Orion hcca d5000 in protection - Orion HCCA-D5000 Car Audio Amplifier
5 Suggested Answers
  • 12 Answers
SOURCE: Orion HCCA-D5000
call orion or check e bay that where i get my parts for my orion.
Posted on Oct 23, 2008
  • 7 Answers
SOURCE: orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Posted on Sep 18, 2009
SOURCE: i have a d5000 amp and its wired up to a 15.2 hcca
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Posted on Feb 10, 2010
  • 3 Answers
SOURCE: I have a orion hcca d5000 and keeps going into
yes mines does the same and everyone keeps saying check the ground upgrade to the big three and so on personally i think this series and there new amps are just junk. Mines been in protect since i got it two years ago, once inawhile would turn off with big bass drop and now the amp doesnt really work in master switch but works on the slave i just think the amp was built poorly so, my advice get it bench tested before you do any new upgrades
Posted on Sep 05, 2010
Power-supply circuit for Orion hcca d5000
send it out to a professional. you need many precise metering tools to measure if everything reads ok, you need to replace other pieces that may not show physical damaged.
Oct 11, 2013 | Orion HCCA-D5000 Car Audio Amplifier
I have a orion hcca d5000 and keeps going into protection. there is nothing hooked up except power, ground and remote. I hook amp to a bit writer and it reads over current. Can this be reset, or is my amp...
Sep 02, 2010 | Orion HCCA-D5000 Car Audio Amplifier
Amp goes into protection straight away.there are no shorted power supply or output Fets
mines does the same i just think the amp is poorly made get it bench tested
May 20, 2010 | Orion HCCA-D5000 Car Audio Amplifier
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion HCCA-D5000
Aug 18, 2008 | Orion HCCA-D5000 Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
21 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
