Question about Fargo Persona C30 Thermal Card Printer
Cannot get Persona C30 to print cards with updated Alphacard syst
I recently took over a job within a sports committee. A computer system was passed on to me with an Alphacard and a Fargo Persona C30 card printer. When I set the computer up, the Alphacard & the printer wouldn't mesh. I figured out how to use the Alphacard and was ready to print, but the program locked up when it was told to print. I saw that the designated printer came up as aDigicard IC 2000, which we do not have. So I changed it to where it said Fargo C30 printer. As soon as I did that it locked up and said Error card software encounters a problem and must shut down Number 5 software error.
I have tried to talk to both Fargo and Alphacard tech people. They had me delete the old versions and upgrade to the newer versions on their sites. I even upgraded the firmware and driver for the printer.
After updating the driver for the printer, the software started to work, but as soon as I changed the printer to the C30 to print from it happened again and froze.
I don't know what to do to fix this!
  • 6 more comments
  • pointskeeper Jan 03, 2009
    When I initially received the computer everything was already installed and had all worked prior to me getting it. The only thing is that the person had unplugged everything to transport it to me.
    The OS is windows 2000.
    right now the Alphacard program has locked up and unplugging the printer does nothing. I can't even open the program.
    I understand what you're saying, but that is what I did this morning. Uninstalled printer, then updated driver. The computer itself recognizes the printer, but the Alphacard program does not want to work with it. As soon as I changed it to the Fargo printer in the Alphacard program, that is where it locked up on me.
    I have reinstalled the software numerous times. Every time it does the same thing. The Alphacard program comes up automatically with a different printer and when I switch it to my C30, it freezes and gives me an error.
    The driver and firmware were both downloaded from Fargo and are the correct ones for the C30. The printer isn't broken because it will print out a few self tests that I tried on the Fargo Workbench.
    When I look for the C30 in the drop down list under the printers to print from in the Alpha Card program it is listed on the bottom with a windows symbol next to it. As soon as I select it it won't send the info to the printer. It just goes to an error message and shuts down the program.
    What I don't understand is that the program and the card printer used to all work fine before I got it. The only thing that changed was it being all unplugged and then plugged back in at my house (probably in different usb ports than what the other person used, but still...).
  • pointskeeper Jan 05, 2009
    Okay so I finally was able to try the C30 printer and Alphacard reader on another computer. This computer also has XP. It installed perfectly, and I was able to print out a card.
    To clarify from before, when I say it locks up on me I mean the actual Alphacard program freezes and shuts itself off "due to an error". The rest of the computer works fine.
  • Fargo Master
  • 19,396 Answers
I am glad you solved the problem by moving the card to a different computer.
On the first computer, a Bios update may have solved the problem.
You find bios update download on motherboard manufacturer website.
Do that if you want to move the card to the original computer.
Regards.
Posted on Jan 11, 2009
    Novelist:
  • 148 Answers
The persona memory buffer is full or communications
hung up
I am assuming you are sending data serialy through the usb port
turn the c 30 off disconnect cable at printer and computer
start computer first connect cables then turn printer on
Posted on Jan 05, 2009
    Genius:
  • 1,913 Answers
Now u have to install c30 printer soft and driver for that.
  • 238 Answers
Install a later version of your Operating System. Check whether the cable is properly connected to your usb port of your cpu unit. If it does, maybe the usb port isn't working try using external usb ports. Install the softwares needed for your C30 printer.
    Brigadier General:
  • 8,619 Answers
Hi , You need to reinstall the windows , and then reload the printer . Also what i suggest is that you can reload in windows xp and then try installing the printer first and then install alpha card.
Thankyou
Posted on Jan 03, 2009
    Scholar:
  • 53 Answers
Try to uninstall every printer including the C30 including the software. Also make sure that the printer driver and firmware are for the C30 and not the C30e, and that they are Win2000 compatible.
Remove every printer cable weather parallel connection or USB and every non essential USB connection to the computer.
Turn pc off for 30 seconds or so.
Turn pc on and install your drivers and software in the order specified by manufacturer, taking care not to connect C30 printer UNTIL asked by instructions, and doing a restart if specified ( though if needed it will probable do it on its own ).
I also noticed that Fargo does not yet have a troubleshooting guide for this model, but they do have a Diagnostic Tool called Fargo Workbench at the following link, which you might want to try:
http://www.fargosupport.com/troubleshooting_results.asp?pr=73
Could be that the guy who brought it to you bumped the printer and broke it! Have you tried to install it on another pc just to check?
I am sorry for your trouble, and good luck!
    Genius:
  • 1,199 Answers
I think this sounds like am ALFA card has gone bad and needs replaced!
    President:
  • 1,952 Answers
Reinstall the software
  • 470 Answers
The software incorporates user-friendly card design and automation tools with database connectivity and a sophisticated information management platform. Alpha Card Software is compatible with virtually all major ID card printers, including Fargo, Zebra, Magicard, and Evolis. It communicates with file-based data sources such as Microsoft Access, Excel, FoxPro, and dBase, and depending on the edition, supports live ODBC connectivity. The software also seamlessly integrates with digital cameras, scanners, and other devices that support TWAIN or WIA.. therefore your alpha card has defected, because no matter what changes did you do it will not work soon, go for the warranty on it, and replace it
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 03, 2009
    f the unlpuggung is perfect , the last option is reformat your computer, because the windows 2000 cannot totaly sustain the system require on the alpha card, use an ULTIMATE VISTA
    Genius:
  • 1,142 Answers
Unplug the printer...restart the system and then plug printer back in when you try to print and when it asks for printer
  • 837 Answers
What OS is on the computer?
  • 2 more comments
  • Jay Glendenning
    Jay Glendenning Jan 03, 2009
    I would also suggest that you remove all the printers (except C30) and retry
  • Jay Glendenning
    Have you removed all the printers except for the C30 from your system, drivers, software,etc from add/remove programs?
    I want you to eliminate all print drivers from the system
  • Jay Glendenning
    Jay Glendenning Jan 04, 2009
    when you say that the system locks up/freezes .. is it the software or the entire system.. I mean can you eventually just do a "normal" windows 2000 shutdown or do you have to power it off manually?
    Also .. have you tried just switching to another usb port?
    Maybe the port(s) you are using/tried are faulty and a "working" port is still available.
    I know that some of this is "reaching" but believe me .. We are trying to help and there is ALOT of years and experiences going on here .. From all of us ...
  • Jay Glendenning
    Try this also .. I know you have done this .. but maybe not the step I am offering ..
    1) Uninstall the printer and the ALPHA software
    2) Remove the folder(s) for the alpha software (i.e.c:\program files\alphacard
    3) reinstall the printer software (usb disconnected)
    4) setup printer (connect to usb, etc)
    5) Just test test the printer for functionality
    6) Install the alpha card software
    7) configure as necessary (see link)
    8) Setup a card and try to print
    ***** What happens ? *****
    Sergeant:
    Champion:
  • 201 Answers
When you first installed the printer did you leave the usb cable out till the software asked you to plug it in and power it up?
  • Jonathan Van Rensburg
    Jonathan Van Rensburg Jan 03, 2009
    Thats the reason why I think its not conected or does not pickup the printer on the usb. PLease remove printer from printers in control panel then reinstall, but keep it off and plugged out till the software askes you for it hope this will help
    OK this is my last advise, reload windows. Or test @ a friends computer to see maybe your windows is corrupted Thank you
Why my persona c30 fargo breaks all ribbons installs Thanks
Mind the printing ofset settings, colour intensity as well!
Aug 07, 2011 | Fargo Persona C30 Thermal Card Printer
Solving Card Jam problem with FARGO PERSONA C30 ID CARD Printer.
Hey I hope you can help me, My c30 persona printer is task, theres a badge inside and cant get out, what can I do?
Aug 25, 2010 | Fargo Persona C30 Thermal Card Printer
Persona C30 Thermal Card Printer: im using fargo printer 30e. everytime i tried to ...
How many prints have been down on the unit?
the most common problem could be the rollers need replacing or a problem with the ribbon sensor. We do repairs and also repair under warranty, How old is your printer?
thanks
May 16, 2010 | Fargo Persona C30 Thermal Card Printer
Need driver for persona c30 for windows 7
Every required driver can be downloaded from this tool: Driver Update Software.
Hope this helped
Donald
Nov 07, 2009 | Fargo Persona C30 Thermal Card Printer
FARGO c30 Won't print, gives following error message run time error -2147417848 (80010108) Automation error. the object invoked has disconected from its clients
You have not mentioned the application you are using.
This is probably not a problem with the printer. this is mostly possible due to macros in the application through which you are printing the cards
try to find out if any patches available for your application.
Also try to install your application again after doing uninstall of the same.
Hope this will definitely solve your problem. Do remeber to run microsoft update for your operating system
Oct 23, 2009 | Fargo Persona C30 Thermal Card Printer
What kind of power cord should i use for Fargo Persona c30 printer
For your fargo persona C30 you need a power adopter of folowing rating description:
input: 100-240V -2A, 50-60Hz AC
output: 24V/2.5A, 60Watt max DC
Aug 21, 2009 | Fargo Persona C30 Thermal Card Printer
Software update for persona c30 card printer by fargo
You need to be a little more precise on your question, I am not sure if you are asking for new drivers for the c30 or firmware? or you have it already and dont know what to do. I'll assume its the first.
go to www.fargo.com to download the latest printer drivers for your C30. Also the firmware is up to 4.6.3 i believe.
thank you
Dec 05, 2008 | Fargo Persona C30 Thermal Card Printer
NT Driver Availability
The only drivers available are Windows 2000 and XP and Windows 98/ME.
May 23, 2008 | Fargo Persona C30 Thermal Card Printer
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
Fargo Persona  C30 Thermal Card Printer Logo
138 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
