Question about JVC Cybercam GR-D70 Mini DV Digital Camcorder
JVC GR-D70U Condensation
My video has keeps showing it has condensation and no matter what I do it does not go away. What should I do?
  • 7200twins Nov 06, 2007
    have same camera had a repair made 2006 it was not allowing me to tape 6months later condensation problem occured brought this to repair shop too much $ to fix is it a recall problem or somethining i can do on my own.
  • BERTIN Dec 06, 2007
Just put the battery on it, and plug it into the charger (which should be plugged into a wall socket). Leave it plugged in like this but not turned on for 24 hrs. Someone else posted this solution above.
It worked for me! And was a lot easier than taking out a bunch of screws.......
Posted on Sep 27, 2009
I found the following website with step-by-step instructions.
It is most likely either a bad sensor or the camera needs a hard reset:
Posted on Dec 03, 2007
Setting the time & date is useless for this problem. i have had mine repaired 2 times for this & its down a third time for the same reason. to me it appears to be a waste of time & money to try & have it repaired. the best solution is to buy a new camcorder, something other than one made by JVC.
Posted on Sep 17, 2007
Set the time and date
Posted on Jun 18, 2007
My JVC GR-D22U is showing a message "condensation,
This is usually caused by a failed component in the moisture detection circuitry within the camera and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Feb 27, 2011 | JVC GR-D22U Camcorder
Jvc gr d240 with a cleaning tape, the camera
its probibly early signs of condensation or a little damp air with faults of this nature same as lense cap fault and or condensation fault leave camera plugged in and switched on for a week . when camera has been on for a while dont put it straight into a bag or case leave it a room temp for a couple of hours after use before putting it away .
Jan 20, 2011 | JVC GR-D240 Mini DV Digital Camcorder
Error message ''condensation operation failed''
1. There is a silver condensation detector in the tape compartment, rear left corner. You can try cleaning this with isopropyl alcohol. I have tried this, and it did not resolve the problem.
2. You can open the camera and unplug the power connector. This will reset the camera, and will resolve the issue for several months. I suggest looking further on this site, where there are instructions for which screws to remove to do this. I have done this, and it has resolved the issued for varying lenghts of time on my GR D30U.
Feb 27, 2009 | JVC Video Cameras
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
I have the same problem and I need a solution. Please, can somebody help?
Dec 19, 2007 | JVC GR-D90U Camcorder
JVC Digital Video Recorder Problems
Most models of cameras have a built in feature to give you a message and turn off if it has condensation on the inside components. Powering back on during this period can cause damage to components. It should remain off in a warm dry area. Condensation might occur in high humidity, or when switching from a cool location to a warmer place. Try cleaning your video heads with a "cleaning tape" let it play for 10 seconds then pause. If that solves nothing your camera may have permanent damage in which case JVC or a repair shop will have to replace parts.
Sep 22, 2007 | JVC GR-DX100EK Mini DV Digital Camcorder
Jvc digital video camera GR-D20 condensation error
Did you ever get this fixed.  I have the same problem and can not use the camera.  please let me know.   thanks
Sep 02, 2007 | JVC GR-D20 Mini DV Digital Camcorder
Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
Jun 21, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
Problem with JVC GR-D70U
It's ... a. A broken connection. b. A failed chip or component. It is not something an owner usually can repair.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC Cybercam GR-D70 Mini DV Digital Camcorder Logo
1,651 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
