Question about Daewoo DVRS04 DVD Recorder/VCR
Unable to connect dvd/vhs recorder to record via freeview box
I have a daewoo dvd recorder + vcr. I have a set top free view box (alba).I cant seem to get the connections right in order to record a freeview chanel.
  • 51 Answers
Can you give me the model number of the dvd/vcr and set-top box?
Posted on Jan 03, 2009
I have a Phillipps dvd/vhs player, a Sony dvd/vhs recorder, a cable box, I have a dvd of a vhs tape already made, How do I make copies of this by using the equipment I have???
Posted on Aug 07, 2009
  • edmaryscott Aug 07, 2009
    The setup I have is I put the dvd I want copies of in the dvd/vhs player and connected the Audio and Video cables to the Out connections of the player, I then connected the other end to the In connections of the Recorder, My question is How do I operate the recorder to make a copy??
    The Model # of my dvd/vhs player is DVP3050V/37
Can't tune Alba 7395 VCR into a Goodmans GDB12XIT Freeview box
Has the box got a scart socket? If it has connect the VCR to that via a scart lead. If the alba has two scart sockets then use the second one. When recording set the channel as AV1 or AV2.
If you don't have enough scart sockets to connect your TV, VCR and Box, then get one of these Scart Switching Box from places such as Amazon or Argos.
Jan 14, 2013 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Hi my mum has been given a dvd/video combi Technika DVR100 as her one does not record her progs while she is at work after the digital changeover.. question is will this record her progs which she watches...
You would have to connect the free view box to the vcr with a scart lead.Plug it into av2 on the vcr.To record select av2 on the vcr then set the channel on the freeview box.
Oct 16, 2010 | Televison & Video
Sony VHS model no: SLV-SE710G isn't recording now that we have a freeview box. It just keeps changing back to L1 whenever i try to record anything!! I only want to record channels 1,2,3,4 !! HELP!!
Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
Aug 20, 2009 | Sony Televison & Video
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
Can't record Freeview
You should have the Freeview box connected to the VCR, then the VCR to the TV
Hope that helps =)
Apr 12, 2008 | Philips VR550 VHS VCR
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Daewoo DVRS04 DVD Recorder/VCR Logo
593 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
