Datton 3E402, rapid cycling ... burner on 42 seconds, then off; then fan on 12 seconds , then off; then cycle repeats. Just started this a few days ago. Thaks, Terrence
  • 163 Answers
Hi!!! you seem to have a bad flame sensor in your heater.Replace your flame sensor..Good luck..
Posted on Jan 03, 2009
Burner shut off then there is a clicking sound, burner ignites again
this is normal the clicking sound you hear is the system starting another cycle for your furnace to ignite the burners, then turn on tbe fan blower.
Sep 27, 2017 | Heating & Cooling
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Own a heil gas furnace. The thermostat is set at 80. Is it normal for the heater to turn on and the burner to come on for 2 seconds, shut off then the fan blows room temperature air, then the cycle is...
Not normal. Is the thermostat located away from a heat supply vent (and direct sunlight)? If so, it will sense temp higher than it actually is, and shut off burner.
Sep 06, 2017 | Honeywell International Heil Quaker...
Trane air handler cycling rapidly
Depending on the age of your Trane unit. The fan relay has a time delay. This is a solid state board on the relay. Most of the time they stick on or off. Check for loose wires. But start with relay.
Jun 03, 2009 | Heating & Cooling
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
The burners go out before the fan comes on
Replace your flame sensor, but before you do that, see if you can clean it with light wool, or emery cloth, or light sand paper. It's a metal rod that points in the current of your flame.
Dec 05, 2008 | Heating & Cooling
The burners go out before the fan starts
Replace the flame sensor, clean the burners to ensure you have a good clean burn pattern and the flame is properly reaching the flame sensor.
Look for a flashing LED and determine what the failure code is.
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
