Question about Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20 goes into sleep mode - Sceptre X20g-Naga III 20.1" LCD Monitor
4 Suggested Answers
furion187
  • 54 Answers
SOURCE: Sceptre X20
reinstall your video card drivers ,
Posted on Nov 16, 2007
budmrtn
  • 11361 Answers
SOURCE: Got a sceptre x20 and
More likely to have power supply problem due to bad caps, that will be the first thing to check.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 30, 2010
reyjoshua07
  • 1157 Answers
SOURCE: grier_rhow do you remove the bezel from the
Hi grier_r46,
Please follow the steps below on how to remove the bezel of your unit.
1. Locate the screws around the perimeter of the Sceptre X20G monitor's bezel.
2. These will likely still be covered with plastic seals, so pop these seals off first and then remove the screws with a hillips-head screwdriver.
3. Remove the Sceptre X20G monitor's bezel. It is now loose, so pull up one corner of the bezel and notice the plastic latches between the bezel and the rest of the display.
4. These continue to tenuously hold the bezel in place. Use a thin, non-metal object to pry between the bezel and the plastic latches.
5. This will unhook the bezel from the latches and allow for complete bezel removal. Take care not to damage the plastic latches during this process.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 22, 2011
Have a Sceptre 32" TV that changes sources all by itself, how do I fix it?
Model Number?
It may have a setting to automatically switch to a new source. Check and see if that is off. Also, power down your other connected devices completely, as some will occasionally "ping" the TV to make it's still connected while in sleep/idle mode. The Nintendo Switch is especially bad at that.
Jun 18, 2017 | Sceptre Televison & Video
Power save mode sleep
Hi Brian,
The printer goes to sleep mode irrespective of what cartridge you have in the printer. Printer goes to sleep mode if the printer is not in use.
Regards,
Sean
Jun 04, 2013 | HP LaserJet 5500 Printer
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
The system goes into Sleep mode every 5 minutes and just before going into the sleep mode,''protection Error'' flases on the screen
Unfortunately, the unit is not going into "Sleep mode".
The PROTECTION error actually means that the unit is overheating.
The unit shuts itself off to avoid further damage.
Try to make sure that no other device is below the unit. Also make sure the unit has adequate ventilation on the back of it.
If not, call 1-800-7267864 and let them set up a repair order for the unit.
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection Error
maybe the audio amplifier IC´s are in bad conditions and need to be replaced
X20 workıng only when ı plug ıt to pc hellp
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 24, 2007 | iRiver X20 MP3 Player
Workıng only wıth pc
Sceptre X20
Nov 16, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
49 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
