Question about John Deere 670 770 870 970 1070 Compact Diesel Tractor Technical Repair Manual
Installed new drive shaft in my 970 4x4 john deere,replaced new ball b earings,and also spring,and carter pin.but when I cranked the tractor and put it in 4 wheel drive the shaft came out
The drive shaft connects from the transmission to housing on the front end.
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Posted on Mar 21, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Daniel S
  • 4323 Answers
SOURCE: John Deere Model 445 garden
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
How do I fix a drive spring on a john Deere L100
usually one would get a new spring and put on the unit .
Oct 19, 2015 | John Deere L100 Series
Why wont blades stay engaged ?
Check the drive pin in the tractor belt drive pulley. If the pin is broken it will have enough pull to turn the blades slow but will slip when the gas is applied. To repair you will need to remove the drive belt and take the pulley off the drive shaft and get a new pin and reinstal.
Jul 24, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
Drive does not work on a john deere 14sb
Wow a 14 sb, The best mower John Deere ever built. Hopefully its just the belt. If it is the transmission cable, they dont make it anymore.. You get a longer one. Before you buy anything, make sure the cable is routed correctly. Sometimes when you fold the handles the cable gets to the outside of the handles, it needs to stay on the inside and not bent ovet the take down knobs. If they are all routed good and it does need to be replaced you will need to order a new lever GX2206 and a new Push
nut GX10434, they are needed for the new cable to work. Hope this helps.
Matt
Nov 09, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
Problem with John Deere L120 tractor
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a 1020 john deere and there is hydrolic fluid in the oil put a new power steering pump on 2 years ago when it was doing the same thing Is there a ball or a setting pin that goes on the end of the...
power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
Apr 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
MY CARBURETOR IS WEAR DOWNWHICH I BEEN PUTTING KITS SO SHOULD I BUY A NEW CARBURETOR FOR 2010 GAS MOTOR,it,s a john-deere tractor
Yes it is time to buy a new carberator unless you know someone who can make and install bushings in the trottle plate shaft, and choke shaft. What normally happens over time is the shaft wears into the housing as it is being used which allows ecsessive air into the fuel air mixer which causes inproper run conditions and no matter how much you adjust all the settings you cannot overcome this condition so its either get new bushings made and installed or purchase a new carberator. Hope This Helps Don
Nov 28, 2009 | John Deere 2010 Tractor Basic Carburetor...
How do I replace a hydraulic pump on a John deere 1050. Where is it located?
The pump is located in front of the engine.A coupler joins it to the front crank shaft pulley.
Nov 06, 2009 | John Deere Steel Chain/farm/tractor/john...
John Deere 670 770 870 970 1070 Compact Diesel Tractor Technical Repair Manual Logo
280 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
