Question about Mitsubishi WD-62825 62" Rear Projection HDTV
Wd-62825 takes a few seconds to turn on
When I turn the tv on the green light shows that it is on but it takes a few seconds to get sound and about 30 seconds to get a picture. What could be the problem.
  • Paul Langkau
    Paul Langkau Nov 02, 2012
    I put the new lamp in and still the same. I know it all has to go threw the lamp ballist right? Do you think it might be the ballast going bad?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The lamp may be showing its age or number of hours of use---typical on this set from cold turn on is up to 15 seconds.
Posted on Oct 30, 2012
  • Paul Langkau
    Paul Langkau Oct 30, 2012
    I got this for free and it had the green blinking light of death when I got it so I never saw it work. After I got it I had bought a rebuilt chasis for this tv and had installed it. I do have a couple of these tv and also in the past year I have been buying the lamps new for a cheap cost so I will give it a shot tomarrow. I also have to add is the pic does seem alittle dark so I will put one of those new lamps in and try that and I will get back too you. Thanks Paul
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
ser71
  • 818 Answers
SOURCE: WD-62525 PROBLEM
YOU NEED A FIRMWARE UPGRADE FOR THIS MONITOR.
SERGIO
Posted on Mar 05, 2008
SOURCE: Mitsubishi WD-62825 Green Blinking light and
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Posted on Sep 29, 2008
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
  • 184 Answers
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Posted on Feb 14, 2009
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
No response from the TV when turned on. Slight hum but no green light flashing....
power supply or mainboard deffective..go to your nearest mitsubishi srvice center
Sep 07, 2010 | Mitsubishi WD-62825 62" Rear Projection...
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi wd-62825 dlp
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
Aug 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV will not power up
does the set do anything what so ever when you press power/ Are there any lights lit on the front at all?
May 29, 2008 | Televison & Video
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
