Using hdmi Have a green shadow on dark areas, with cable in looks great, not sure if color wheel or ram, anybody have tips will be great
Try using different hdmi slot...if that works the previous slot is pulled away slightly
Posted on Oct 29, 2012
lukster
  • 217 Answers
SOURCE: Green shadowing on Samsung LN-S3251D
sounds like you need a service call if it's in warranty, if not in warranty, you may need to have the logic main board replaced
Posted on Apr 30, 2007
SOURCE: blue area near center of screen
It may not be the light engine. I also have the cloud, and since I was told that touching the bulb surface could cause problems, I took out my bulb to take a look. The fault is Inside the bulb. A cloud has formed on the inside of the bulb dead center. I have a feeling this is the problem and replacing the bulb again is going to be the solution. By the way, I buy the bulb alone and put it in the casing myself. The last time I got a replacement the casing was slightly and I do mean slightly, out of line with my set.
Posted on Feb 27, 2008
DR NITIN
  • 221 Answers
SOURCE: Green shadows in dark scenes
You should contact Service Center to resolve this issue.
Posted on Jun 18, 2008
SOURCE: Problem with the picture on my Vizio flat panel
I work as a Contractor for Vizio repairs, and I can tell you that the only solution is to replace the motherboard, or if under warranty REPLACE IT! I have had situations when I replace Motherboard and within 2-3 hours the TV is making either Green, Red, Or Blue pixels where dark areas are. If under warranty don't accept any thing but a full replacement.
Posted on May 08, 2009
SOURCE: Bush iD HDMI 37inch tv
how do i change the locking code
Posted on Jun 21, 2010
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Tip
How to Put on Eye Shadow
Achieving Smoky Eyes.If you're looking for a way to play up your eye color, go smoky. A smoky effect makes eye color pop and creates a dramatic evening look. Read on to learn how to create a flawless smoky eye. <br /><br />Create a smooth canvas for eye makeup. First, you'll want to apply a primer to your entire face, including the eye area. Then apply a concealer to get rid of redness and dark circles. Finish off by applying a moisturizing foundation to create a flawless canvas. <br /><br />Apply eyeliner. Use a black liner and draw a line across the upper lash line. When you get to the middle of the eye, make the line a little bit thicker. Choose a lighter-colored eyeliner and line the bottom of your eye. Smudge the liner with your finger to create a smoky appearance. <br /><br />Apply two colors of eye shadow. In order to select the right products, check out eye shadow reviews. You'll want a color palette that has both a light and a dark color, such as L'Oreal Paris HiP Concentrated Shadow Duo. Use the lighter color as a base and blend the color all over your upper lid. Then, apply the dark eye shadow, starting at the lash line and blending upward.
on Nov 22, 2010 | Health & Beauty
I have a Samsung DLP HLR5067 modeel tv, recently we have replaced the lamp, ballast and color wheel. The color is ok but when we watch dark (color)movies the black and browns look shadowed and irdescent. ...
You probhably have the wrong color wheel. There are several different ones and its imparitive that you replace it with the correct one. If you search here theres someone else that had the same issue and when they put thier old noisy color wheel back in the problem went away.
Nov 15, 2010 | Televison & Video
When my samsung LNT5271F is turned it has a DELAYED DISTORTION on the right side half of the tv ,, after about 30 minutes the distortion will get a little clearer but not completely, then a DARK SHADOW...
I have the same TV and it's doing the same thing but on the left side. We had a local repair shop come out to diagnose and he told us this is the result of a loose ribbon cable on the LCD panel that would require replacement of the LCD panel - cost would be about the same as a new TV.
Aug 31, 2010 | Samsung LN-T5271F 52 in. LCD Television
When turning on my 32hdt50 it changes color from
It has to do with the cables. Since you do not stipulate what cables you are using it is hard to tell. Make sure all are seated well and match the Cable box output cable colours. If Component cables the usual mistake is switching the blue and green since they look alike. If using HDMI make sure it is seated firmley in connector. Another problem might be a bad cable.
Nov 09, 2009 | Hitachi 32HDT50 32 in. Plasma Television
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Pink shadows
you need to get the HDMI cord.
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
COLOR
Are you using the component inputs from the DVD player (blue, green, red)? HDMI? If using the component cable, it sounds like one is in the wrong slot. If using HDMI, try looking at the setup in the DVD menu to make sure it is using the correct output. I had a samsung DVD player that kept trying to use the component output even though I told it to use the HDMI and my picture looked red. Let me know.
Jul 31, 2007 | Olevia LT27HVX 27 in. LCD Television
Problems with subtly changing colors
What connection are you using, HDMI or component?
Also, on what source is the problem happening, through sat or through off air antenna?
If you're on HDMI I'd try component. Then, playback the affected video and see if it's reproduced w/ component.
If it's on ota only, you may have a loose tuner cable inside. It's easy to fix, you need a torx t-10 screwdriver. Unplug the unit, take the 5 torx screws off of the back cover, and on the right side you'll see 2 cables running from tuners in the front to a splitter that connects to the tuner for ota on the back right. Just make sure the connections are tight with your hands only, don't over tighten them. Also, make sure you don't touch the power supply when you have the unit open!
Apr 06, 2007 | Directv HR10-250 DTV Receiver
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
