Question about Microwave Ovens
Can't find the bulb/light
The bulb has gone, and i can't see a way into it. Please help.
  • raynich2 Jan 04, 2009
    Thank you for assistance. I don't have instructions, my Microwave is: ONN 0m009
  • Microwave Ovens Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 03, 2009
  • William Miller
    William Miller Jan 04, 2009
    I don;t have data for that one.
    I'd have to refer you back to my general solution above.
The microwave is working but the light is not lighting up when in use
The oven bulb will have gone. Read the instructions about replacing the bulb.
Apr 17, 2017 | In Microwave Ovens
The light has gone out on my oven.. Is it the bulb?.. Or is there a battery compartment?
The bulb needs to be replaced, or if the bulb is good, then the circuit needs to be checked.
Jun 03, 2015 | Microwave Ovens
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
Nov 17, 2014 | Microwave Ovens
The light has gone out.
make this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Whirlpool Microwave Ovens
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Dec 22, 2009 | LG LRMM1430 Microwave Oven
When i plug in the microwave it starts running & will not stop
Sounds like you blew a device on the main board when you didn't unplug it first. The whole main timer board must be replaced to repair the unit. Pricey, sorry!!
Aug 01, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Microwave R-206 800W
open the housing, look where the bulb is located, unscrew the holder of the bulb and if the b.ulb is screwed at the holder, replace it. if the bulb is attached to the holder then replace the whole bulb assembly. i hope i was able to answer your problem
Feb 18, 2008 | Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
