Question about Fisher and Paykel Washing Machines
Now and then my Smart Drive Fisher and Pykel squeals when starting to spin.
Just every now and then when doing a wash I hear the machine starting to squeal when starting to spin but it does not do this each and every time. I think it is when there is a larger load in the machine.
  • Dyson Nicholson Oct 30, 2012
    Thanks for your suggestions but I have been told the smart drive excellence does not have belts. Could it be a bearing and how difficult is it to replace.
  • Fisher and P... Expert
  • 554 Answers
You will need the seal & bearing kit & maybe a shaft,
It is a big job to do,
The whole machine will need to be disassembled to do that repair.
Posted on Dec 31, 2013
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
TaPuna
  • 70 Answers
SOURCE: Smart Drive 703-strange noise during wash cycle
hi there these washing machines don't have any pelts or pulley's. Washer will need new seals and bearings witch is a big job, you wont be able to do it your self as you need special tools to put the bearings back in :)
Posted on Sep 09, 2008
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
SOURCE: Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
Posted on Mar 30, 2010
Error 49 on a Fisher and Pykel washing machine, what can i do to resolve this?? Thankyou.
Your cold valve is faulty. The rubber membrance inside the valve can damaged after certain period of time. The problem may be inside the controller if replcement valve can't fix the problem. There is a resistor on the current path to the valve. It is on the control board. Some timems it can go open. Good luck with the repair
Regards
Sarath
Apr 15, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel top loader smart drive 053 has started to sqeak when spinning
drive belt may be loose and squealing just like a car will suggest re placeing it at that age.
Jul 09, 2012 | Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Jun 19, 2010 | Fisher and Paykel (IWL12)
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
85 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
