Question about Cuisinart DLC-5 Food Processor
Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
I dropped our food processor and cracked the hard outter housing. before I use duck tape, is there a way to get this replaced?
  • 1 more comment
  • dogwalks Jan 04, 2009
    Many thanks---never thought to look!
  • lrossavick Jan 06, 2009
    Our DL7E has three cracks on top from use over the years? Is there a repair service? Or buy new?
  • H M Hoppe Dec 10, 2012
    You can buy the part from Cuisinart customer service -- but you need to call them, the parts are not shown on the website.
    New Friend:
    Problem Solver:
  • 18 Answers
The Motor Shaft Cover parts are not shown on the Cuisinart website under parts, but they are available if you call Customer Service. These parts are quite inexpensive (often $3 + s&h). Have your model number ready, and they can get the right one out to you.
Posted on Dec 10, 2012
I've seen them for sale on ebay. Take a look there.
Posted on Jan 04, 2009
Why Cuisinart mixer will not start?
All Cuisnarts have an interlock rod built in to the bowl assembly.
Make sure the bowl is positioned on the motor base correctly, and the actuator in the lid that pushes the interlock rod down is not bromen or damaged. If it is intact and working correctly, then check the switch it pushes on, or the main power switch.
May 20, 2014 | Cuisinart DFP-11 Deluxe Food Processor
Cannot remember how to put together and get it to run. Need online instructions.
here is the manual online
http://www.cuisinart.com/share/pdf/manuals/dfp-11.pdf
Jul 02, 2011 | Cuisinart DFP-11 Deluxe Food Processor
Cuisinart DFP-11 Deluxe 11 Food Processor Motor Shaft Cover is broken. Can this part be replaced by the user? What part number is required? The manual does not provide this information and the processor...
You can get the Motor Shaft Covers for most if not all Cuisinart models from their customer service. They are not shown on the web under parts, but if you call them, they can help you get the right part. Just have your model # ready. For many, the part is $3 plus shipping and handling.
May 13, 2010 | Cuisinart DFP-11 Deluxe Food Processor
Doesn't start
check to make sure micro switch is engaged, will not turn on because of safety switch . if overloaded the thermal fuse has blown inside the machine. check to see if you have voltage , you may need a voltage test meter too and tools
Mar 13, 2010 | Cuisinart DFP-11 Deluxe Food Processor
Won't start
Make sure it is unplugged !!! If you have a blade tool, Rotate the motor several times in direction of normal rotation. Then all clear, plug it in and see how that does. Repeat if necessary. Sometimes the brushes in the motor are seated and turning the motor helps the realignment. mAKE SURE TO UNPLUG IT!!!! Ned
Oct 30, 2009 | Cuisinart DFP-11 Deluxe Food Processor
How to us cusinart 11 cup food proceessor for chopping. cutting.
You can download the user manual for the DFP-11 from
http://www.cuisinart.com/parts/food_processors/dfp-11.html
Click on the "download user manual" hypertext link on the right under the processor picture. You need to have Adobe Reader loaded to be able to read the manual.
Please rate this solution. Thanks.
Oct 22, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Cuisinart does, in fact, have the replacement bowl parts for the DFP-11
Jan 03, 2009 | Food Processors
Motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Dec 19, 2008 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart DL 11: Cracked plastic drive shaft
If it is in warranty, it can be sent to Cuisinart for repair. If it is out-of-warranty, it will cost more than a new food processor to repair.
Dec 11, 2008 | Cuisinart DFP-11 Deluxe Food Processor
Won't turn on
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
The manual is available on Cuisinart's website
Nov 27, 2008 | Cuisinart DFP-11 Deluxe Food Processor
Cuisinart DLC-5 Food Processor Logo
179 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
