Question about Acer Iconia Tab A200
Can not get to wifi
I can get to abs, but not wifi
  • Acer Master
  • 27,725 Answers
Wi-Fi technology enables wireless Internet and network access through public and private hot spots.
These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel.
To connect to Wi-Fi, you must have an enabled wireless adapter on your computer.
Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities.
However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna.
Hold the "Fn" key and press this key to toggle wireless on or off.
Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter.
Attach the USB wireless adapter to an available USB port on your computer.
Windows 7 will automatically install the necessary drivers for most adapters.
If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers.
Restart your computer if you do not see a wireless icon in your Windows 7 notification area.
Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect.
If this is your home network, the correct network will likely be the one with the strongest signal.
Click "Connect" and enter the wireless security passphrase, if required.
Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead.
Open your browser and navigate to any website.
If the hot spot requires browser authentication, your website request is redirected to an information page.
Follow the instructions on this page to get Wi-Fi.
This may entail clicking "Accept," entering a given password or entering a cell phone number.
After authentication, attempt your website again to verify accessibility.
Hope this helps
Posted on Oct 29, 2012
I have an iPad mini cellular. What should my settings be to use wifi when not in a wifi area
When you're on cellular, the wifi can be turned off, or left on. It's not a big battery drain and if you enter a wifi area, it'll switch to wifi saving your data plan. I've always just left mine on, but I turned off the prompts for new wifi networks.
May 05, 2017 | iPad mini Tablets & eReaders
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
If i activate my tablet do i have to have wifi in my home ?
No Belinda, you can use it without wifi at home if you don't have wifi. When you are out in a public place, you can use public wifi. Coffee shops, bars, restaurants and places have free wifi.
Dec 01, 2015 | Tablets & eReaders
I can't connect to wifi and when I can I can't setup my gmail account or any other apps I have try everything I know
I'll give you some help on ANDROID. Go to apps, settings\ WiFi. Turn it on at top of screen. Any available WiFi accounts will show up. Then go to top right push the three dots, click advanced and make your choices. Click back to WiFi screen and click the WiFi you want to connect with, enter the key that your WiFi needs to connect, or use the WPS option if available on you WiFi. If the WiFi has WPS, push the button on the WiFi and connect your tablet or phone by pressing connect.
Nov 29, 2015 | Tablets & eReaders
Wifi not working in house
How is your WiFi configured at home?. Do you have MAC filtering for instance set up? (i.e. filtering to only let specific machines use the WiFi based on their hardware addresses)
Mar 28, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Wifi error on easypad 970
check you wifi and see if its ok.. are there too many items on it trying to run?..as in more than 4 computers..
Jan 07, 2014 | Easypix Easypad 970 9.7 Inch Tablet...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Wifi for my Tablet
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
Jun 11, 2013 | Tablets & eReaders
Wifi issue
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
Oct 17, 2017 | Lenovo Tablets & eReaders
Acer Iconia Tab A200 Logo
330 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
