Question about Tissot Sea-Touch T026.420.11.051.00 Wrist Watch for Men
Sea touch stuck at 12 0 clock
Stuck a 12 o'clock still show a little battery left
Minute hand on Braun AB1A has curved up stopping second hand
The whole front square face of the clock has 4 little nails which are located in the middle of each side (inside and next to the edge of the joint), so you have to carefully insert a screwdriver and lever the front out. After this you have to remove the hands (remember to set the clock and alarm hand to 12:00 before taking those away). The face will be loose, and you'll have access to the mechanism. Clean the alarm contact (look for a double silver metal arm that touches an small bronze stick. Alarm button can be release by gently lever the little nail that shows in the center when button is up at clock's backside.
Cheers from Argentina
Jul 04, 2012 | Braun Ab1a Alarm Clock - Black By Rams &...
Ultronic clock, humidity & temperature. How does one read the "Temperature Trend" scal on the lower left of the screen. There are three scales shown and the indicators on the scale keeps...
This clock keeps track of the temperatures for each of the last 12 hours. So on the bottom, you'll see the temp at 12 hours ago (-12), 6 hours ago (-6), etc. On the left side, you'll see the temperature in Farenheit go from +5.4 to -5.4 from where it is currently. So if the temperature is 70F degrees right now, and it was 65F degrees 12 hours ago, then it'll show -5 in the first -12 column. It will always be at 0 for the current hour on the right. The scale on the right is in Celcius so it does the exact same thing as Farenheit.
Mar 01, 2011 | Watches
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
Feb 27, 2010 | Tissot T-Touch T33159851 Wrist Watch
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
I need calibrate Tissot t-touch
Syncronisation sequence is in the user manual. syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time. If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
Jun 04, 2009 | Tissot T-Touch T33759851
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Tissot Sea-Touch T026.420.11.051.00 Wrist Watch for Men Logo
29 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
