I replaced the drive shaft with a new one including new bearings. But as I put it in 4 wheel drive,it slung it back out. I pull the spring back and put the carter pin back in but it still wouldn't stay in.
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
SOURCE: steering bearings keep coming apart johne deere
The C or E clip is worn and needs replacing if it keeps poping out of the grove.
SOURCE: how do you replace a broken pto shaft in a 1979 2840 john deere
drill into it and use the biggest easy-out you can get your hands on.
