Question about Sony VAIO E Series SVE15115FXS Laptop
Ever since I attempted to change the microphone levels and boost it started making a static noise when i webcam. I already change it to original setting but it is still making a noise.
    Scholar:
  • 106 Answers
Simply go to My Computer, Right Click, select Manage, and then device manager, right click on your device name and then uninstall it. Then go to the top and click Refresh or F5 and let the windows o/s install the driver again. Restart your computer and it shall be fine.
Posted on Oct 29, 2012
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Hi. I've connected my Shure 55SH to my netbook via XLR to 1/4", then with an adaptor to my 1/8" port. My recordings all have significant fuzz, but the level doesn't change when I adjust my...
Most likely the 1/8" jack's input is LINE level. The microphone works at a higher IMPEDANCE and will have to be boosted to line level in order to have a matching impedance to the input on your netbook. You can use a mixer, a DI box, or microphone pre-amp to match the LINE level of your 1/8" jack. That will give you more control over level with less noise.
Mar 01, 2011 | Shure 55SH Series II Professional...
Microphone not working
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Jul 01, 2010 | Logitech Webcam
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
Cannot hear my voice in the skype test skype is set up on the ubuntu operating system
Firstly, what version of Ubuntu and Skype are you using? Also what machine.
There are three areas where the issue could be - within Skype's settings, withing Ubuntu's settings or with the microphone/soundcard.
I'll cover some quick attempts at solving, assuming it's the first two.
OK, first make sure Ubuntu's settings are correct. If you can access the sound settings (generally there is a Speaker icon in the top right). Right click, 'open volume control'. Often you need the 'boost' level as well as the usual microphone - if you have 'Front Mic', sometimes you need 'Front Mic Boost too', likewise if you have 'Microphone', you might need 'Microphone Boost'. In the Volume Control, click preference to add the 'boost' level.
If that didn't work it might be your Skype settings. In Skype options, 'sound devices' try changing the 'sound in'.
If those didn't work it might be hardware (or another trickier software issue) - try testing your microphone on something else.
Feb 27, 2009 | HP Compaq nx9030 Notebook
My webcam works fine but the microphone crackles all the time
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Feb 01, 2009 | Logitech Webcam
Nov 14, 2008 | Microsoft LifeCam VX-1000 Webcam
Microphone issue
Maybe there is more than one setting for the microphone. Possibly the camera/mic software has settings that it is using when in use, or maybe it has an "auto" setting. Try adjusting or disabling this.
May 15, 2008 | Logitech QuickCam Communicate STX Personal...
I get a humming sound when I record a video
There a quite a few reasons why this could happen.
  1. The sound device could be malfunctioning.
  2. The cables are not plugged in all the way.
  3. The camera may be close to a noise maker such as a fan, air conditioner, or your PC fan.
  4. The sound wires could be crossed with an electrical wire which sometimes creates static or a hum.
  5. If you are using a normal Microphone, there could be static on the port or connector.
  6. The record volume levels are too high, or mic boost has been enabled and is picking up extra sound.
I hope one of these examples helps to fix your problem, if it doesn't, please get back with me and we can try something else. Good luck!
May 03, 2008 | Microsoft LifeCam VX-3000 Web Camera
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Sony VAIO E Series SVE15115FXS Laptop Logo
144 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
